need N2O plumbing advice
Results 1 to 7 of 7
    031 RIVER4FUN's Avatar
    Default need N2O plumbing advice
    Edelbrock fogger, 250 shot. I have a dedicated Holley blue fuel pump & reg. Planning on using -8 fuel line up to the Y-block, then reduce down to -4 to the solenoids. Then , -6 out of the bottle to the Y-block, then reduce to -4 to the solenoids. Thoughts, Advice ??
    The Man cordog009's Avatar
    East Texas
    Quote Originally Posted by RIVER4FUN View Post
    That's basically what I'm doing on my dual-quad setup. It's a fixed 250 shot as well. Holley blue & reg. with -8 fuel line to the solenoid and -4 to the plates, and -6 from bottle to solenoid then -4 to plates. Running a IMCO 2.5gal bullet tank.
    1984 Youngblood TX-19 SOLD
    Cantard 71hallett's Avatar
    snow bank
    Make sure you run one port on the reg as a bypass with a -3 or -4 line to keep the fuel side full. about it.
    yep, if you use the holley crap regulator and use a low pressure safety switch , you'll be goin down the track with nitrous turning off and on because of a crap regulator. run a bypass type regulator as close to the fuel solenoids as possible.
    snow bank
    x2 those holley blue pumps cant keep up to the saftey switch.........switch removed and tossed over the fence.....works now
    i've had it happen to me in my gullwing whie sprayin a 450hp 2 stage shot talk about disrupting a boat i just let outta the 2nd stage and kept the 1st stage nailed till it came back on
    snow bank
    Nice!
