Bolt Stretch/Tension
Results 1 to 14 of 27
    Default Bolt Stretch/Tension
    Can someone please explain the theories behind bolt tension and stretch and what the proper procedure is for torquing main cap studs and rod cap screws?
    when you tighten a bolt, you need to achieve the proper preload for the bolt to do its job. The bolt stretches a certain amount when you tighten it. In the case of a rod bolt, the bolt has to have enough preload/clamping force to overcome the load that's trying to rip the rod apart. the reciprocating motion of the crankshaft and piston is constantly trying to pull the connecting rod apart. the load is greatest at tdc and bdc when the assembly changes direction. Rod bolts are the highest loaded fasteners in an engine.
    measuring the length of the bolt before you torque it, and then afterwards with a bolt stretch gauge will tell you how much the bolt has stretched. Most bolt manufacturers will tell you how much the bolt needs to stretch to work properly
    The reason its better to measure the stretch of a bolt than simply using a torque wrench is because the coefficient of friction between the bolt head and washer or rod, wont be the same for each bolt.
    For example, i just measured the stretch when assembling the rods on my BBC. most of the bolts would stretch the recommend amount (.0050-.0055) with 70 lb-ft of torque, but there were 3 that need another 10 lb-ft of torque to get the proper stretch. Had i not measured the stretch and just torqued the bolts and called it good, i might have had a bolt failure at high rpm.
    arp makes a really nice gauge.
    Very good info! Exactly what I was looking for.
    One more question...is it just the rods that need to be tightened with a stretch gauge, or do main bolts/studs need to be also?
    there's no way to measure the stretch of a main stud/bolt. check out the photo of how the stretch gauge attaches to the rod bolt.
    Makes perfect sense. The bolt will stretch in both directions and with a main stud/bolt there's no way to get the gauge onto the other end of it since it's in the block.
    I'll be running ARP main studs. I know with studs you don't bottom them out...there's an actual procedure for proper torquing of studs. Can you explain that procedure for me?
    Again thanks for all the info.
    Newton Ks.
    If you look at ARP's catologue, page 43, they tell you how to install them.
    "Finger-Tight" in clean threaded holes WILL bottom them out.
    They even advise them, if it is to be permenent, to be Lock-tited into place (install and torque the caps before the Loc-tite is set to prevent mis-alignment).
    1- Clean and chase threads, calibrate torque wrench.
    2- clean caps and hardware.
    3- screw studs in untill FINGER TIGHT, Lock-tite if desired.
    4- Install caps, lube threads.
    5- Torque to values with stud instructions 3 times, torque before thread sealer sets up.
    ARP Catologue
    H.L. Mencken
    havn't posted in a while i got the flu, sorry
    smokinlow means this is for main studs/ not rods
    but same arp cat for rod bolts specs
    what some people miss is lube arp moly grease for threads and under fastener head and washers, this will make a big impact on values.. tq and stretch
    i like to cycle each bolt and studs at least three times before i reach final assembly
    clean up excess lube after your done this stuff is not good on rod bearings and filters
    i sure these guys will chime in and show me just how sick i am.
    Newton Ks.
    Sux flat, hope you're better soon.
    H.L. Mencken
    Newton Ks.
    Quote Originally Posted by flat601 View Post
    Yep, as I told Jetaholic on the horn last night, where I work, aircraft wheels are 2-part, bolted together. Moly greaase goes on all bolt mating surfaces.
    The washers on both sides (bolt head and nut side), and the bottom of the nut, all those friction surfaces..
    This minimizes any affect of that material drag from affecting the torque values to the bolts.
    We don't grease the threads deliberately, but it's hard to keep them dry greasing everything else.
    Self-locking (crimped) nuts anyhow.
    H.L. Mencken
    B1 Racing cs19's Avatar
    Yep, it wont be long.
    Good post BTW.
    CS
    B1Racing.net
    Someone will always chime in Hope you are not implying that it's OK for main and cam bearings
    LOL.
    There it is Flat601.
    B1Racing.net
    im am sick as a dog and you got to be kidding? ya gn7 just in your motors, yes i seen the pics, right back to ya
    Ladera Ranch
    If you bottom out a main stud in the block couldn't you measure how much it stretches? I realize their may not be a fixture available for the dial indicator(maybe there is), but if it cant go any deeper, it has to stretch where it can be seen,right?
