small pattern nuts for exhaust logs
Results 1 to 8 of 8
    Some guys never learn. bocco's Avatar
    Livermore, CA
    Default small pattern nuts for exhaust logs
    I need some help locating nuts to attach ths snails to my exhast logs. The ones that came off were 5/16-24 with 7/16 across the flats. The way my snails are machined that's all that will fit. Standard 5/16-24 nuts are 1/2 across the flats. Most of mine got rounded or damaged enough that I don't want to reuse them. Anybody know where I can buy these small pattern nuts? Can't find anything on line.
    Gary
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    Quote Originally Posted by bocco View Post
    Gary
    have you tried the 12 point bolts ? Check with Alan ( the boltnatzi) he will hook you up !
    [/SIGPIC]
    Livermore, CA
    Quote Originally Posted by Lucky View Post
    Can't use bolts. The way the snails are made I only have room to put the small nuts on.
    Ukiah,Ca
    the have small tiney heads small small -- looks like my penis after a swim in coloroado river in january
    [/SIGPIC]
    Rancho Cordova. CA
    Can the studs be pulled and allen bolts put in place??
    Livermore, CA
    I ordered some 12pt ARP nuts from Summitt. Says they fit a 3/8 12pt wrench. The wrench clearance for these nuts is really tight. And no room above for an allen wrench.I'm probably going to have to take a grinder to a cheap wrench to get these on.
    Livermore, CA
    just buy these, easier, faster and probably cheaper and you get new studs and spares
    http://www.jegs.com/i/ARP/070/400-1402/10002/-1
    http://www.jegs.com/i/ARP/070/100-1402/10002/-1
    This is basically what I will end with. I already have the new studs in the kit from Rex. And the nuts are the same.
