Bbc Id????
Results 1 to 14 of 14
Bbc Id????
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    Default Bbc Id????
    Anyone know how to ID the different generations of BBC blocks from the outside?
    Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    Colfax, Ca
    mortec.com
    Quote Originally Posted by Jim W View Post
    Jim
    If it has a mechanical fuel pump mounting boss it's most likely a MkIV (although some Gen VI blocks had one too). There's also a sequence code stamped into a small machined surface right above the timing chain cover that will tell you the factory, month, date and year that the block was made at.
    If it's a 2 bolt main it's definitely a MkIV. Gen V and VI blocks are all 4 bolt main. With MkIV blocks, some were a 2 bolt and some were a 4 bolt.
    MkIV blocks also used a 2 piece rear main seal while Gen V and VI used a 1 piece rear main seal.
    Hope this helps.
    The Man cordog009's Avatar
    East Texas
    Gen VI has a 6 bolt timing cover:
    1984 Youngblood TX-19 SOLD
    Cantard 71hallett's Avatar
    snow bank
    Hey Jim.......most of the gen 5 and 6 blocks also have a liter size writen on the side of them between the pan and the head.
    I was working on the Hallett floors and rear seat and pondering if the engine is gen 5 or 6.
    Mortec will give me a answer.
    Jim
    GN7
    Engine junkie
    Thermal, CA
    Jim
    cordog009 posted the answer,
    Gen V has a 10 bolt timing cover
    Life's journey is not to arrive at the grave safely in well preserved body, but rather to skid in sideways, totally worn out, shouting"....holy shit.... what a ride!"
    I have NEVER owned a MK IV that didn't have a 7.4 on the side. I know they all don't, but a ton of them do. The timing cover is the easiest way to tell a GEN 6
    snow bank
    8.2 exc
    8.2 exc
    Let me re-phrase, "that didn't have the litre size on the side of the block
    Senior Member bp298's Avatar
    LHC
    Jim
    this is the most comprehensive list i've seen.
    http://www.chevcarclubvic.org.au/tec...ng_numbers.htm
    Newton Ks.
    Yep, mine is cast 7.4 as well, 1977 Mk-IV.
    H.L. Mencken
    snow bank
    But I would have to count on both hands to get that big a number....pointing with 5 fingers at once I would probably get all confused.
    Right rear of block, just under the deck will give you an I.D. number that you can check on Mortec. M
