BBC Rod question
Results 1 to 11 of 11
BBC Rod question
    Senior Member Scapegoat's Avatar
    SoCal
    Default BBC Rod question
    I have a set of eagle h beam rods with .927 pin bushings. In marine app will the hold up ok? would it be better if I change to .990 bushings.
    Quote Originally Posted by Scapegoat View Post
    .927 is a small block pin, how long are those rods?
    SoCal
    6.135 BBC rods
    From eagle I guess some drags racers like to run lighter pins. I was told I could change the bushings. I don't know if machining the rods would be required.
    6.135 BBC rods
    Sell those and buy a normal set Brian. By the time you spent money on those you will be money ahead.
    Dec 2010
    Sapulpa ok
    Oliver Is the only way to go. Been beating the same set up for 11 years changed the bolts @ 10 years
    Quote Originally Posted by piston in the wind View Post
    While that's great that Oliver rods have worked fine for you, that is not a correct statement. There are all kinds of good rods that will work for various combinations and demands. As it happens, I know Scapegoat and doubt that Oliver rods are in his budget, nor necessary for what he is probably going to build.
    SoCal
    Double post
    SoCal
    Barry, consider it done. Thanks.
    Olivers are a bit much for my needs.
    There are plenty of .927 pins making 100 hp per cylinder
    Quote Originally Posted by MACHINEHEAD1 View Post
    But it would mean a custom piston, instead of something off the shelf. Likely they are lighter sbc pistons as well.
    I think it would be simpler for him to sell those rods and go with a conventional .990 pin. He was local to me before my move to the river, had been by my place a few times,, trying to keep things simpler for him.
    SoCal
    Thanks guys, especially Barry. I want to keep thinks pretty standard for the most part,nothing radical as I won't be winning any races.
