GM B/B 10141274 heads 100cc Gen 5-6
Results 1 to 14 of 15
    Jul 2015
    Default GM B/B 10141279 heads 100cc Gen 5-6
    Any one running these heads.Do they work. Doing a mild build in a heavy boat with twins.Thanks
    waterloo
    Quote Originally Posted by fenderjack View Post
    Yes, they "work".
    Wags
    Maybe thats a 10141279? Vortec casting. Be careful of your combination so you don't get too much compression, make sure to take that 100cc chamber into account. Should give good low end power, depending on how high you plan to turn the engines, maybe not my first choice on a "performance" type build.
    Senior Member capnfyr's Avatar
    Jun 2011
    Middleton, Idaho
    Default "Vortec" heads
    I've used those "Vortec" heads on several engines but only for tow vehicles. They are great off idle and pull well to about 4500-5000. They would benefit from porting however their intake runners are fairly small and the valves are 2.06 and 1.72 respectively.. They are a big improvement over the "peanut port" head but I wouldn't put them on a performance boat simply because of the restrictions. Now if you have an old 454 in a truck with flat top pistons with the "peanut port" heads I wouldn't hesitate to swap the "Vortecs on it. With the 100cc combustion chamber and better swirl technology you would pick up a significant performance increase.
    Capnfyr
    1984 Daytona Sprint. AKA "Pyro Flyer" 2016 APBA High Points GPS 95 Champion.
    GN 8 AKA "Tinman" Under Construction. Back on the water for 2018.
    21' Eliminator Sport V Drive Lake Cruiser
    [SIGPIC]
    Jul 2015
    Default 10141279 heads
    Wanting to put them on a 38' Chris stinger.Big boat 9'4" beam max 5000 RPM twin 454 30 over flat top pi
    stons and a mild cam.Family boat wanna cruise around 3500 RPM single 4 barrell.9500 lbs
    Jul 2015
    Default heads
    Any other input before I bite the bullet. Thanks JOHN SR
    Without having all the specific dome volume, deck height, etc. Plan on compression ratio going up about 1 point over a 119cc head.
    You are planning on running premium fuel?
    Jun 2011
    Middleton, Idaho
    We need more information on what you currently have in your boat before anyone can give you any real good advice.
    Capnfyr
    [SIGPIC]
    Jul 2015
    Default heads
    NONE as I stated trying to do a mild 454 builds,flat tops mild cams.Wanna a cruise at about 3500 top out 4400 /4800.Big boat .( 9 foot beam) 38' stinger want to cruise not run hard.Hyd. cams,single 4 barrel's.Standard deck.Just want to know if these heads will work .
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Is this boat running twin engines? Is that what I am getting from your post? and you are trying to buy 4 of these L-29 heads to replace some existing ones? or building new GEN 5/6 motors?
    Barry is the expert on these things, but still needs to know: Which heads were on them before? same or other? Are you changing the head type? Rectangle, round or oval ports? Your intake will have to match.
    But for basic low rpm, 400-450 hp use those heads will work.... but they lack in other places, adjustable rockers for one.... small intake ports, cam range, etc
    Jul 2015
    Default heads
    I have NO motors in the boat never did,Yes it is twins it is a 38' boat.Starting with short blocks flat tops. going to put mild cams in them. My question will these heads work.I have a chance to get them but don't know if they will work for what I want to do.I understand they are oval ports.That's why I asked the question will they work In the boat just wanting to run them at cruise 3300 3400 RPM. Not a all out offshore boat.
    You have several people who have answered, besides myself. They will work,,,,,,,but, pay attention to what I said above!
    My main points were to make sure what compression you will end up with, and make sure to run premium gas with a big boat and 9-1 (give or take) compression.
    Jul 2015
    Default heads
    Thanks Guys for all your help.Got the heads just wanted to back up my own thinking and you guys did.Very happy for you help.John Sr
    ptc
    ptc is offline
    Oct 2010
    Sacramento Area
    Buying heads before the blocks....? dont quite understand it all but thats the way it goes.... Id be looking for some complete motors first - there are tons of them out there ready to drop in and go!
