Dry sump systems
Results 1 to 14 of 14
Dry sump systems
    May 2014
    Default Dry sump systems
    Let's see what ya got and how you plumed it
    Working on mine right now and just lookin for ideas and knowledge
    Mohave Valley/Quartzsite
    I'm actually finishing mine up this weekend.. What kind of pump do you have and how many outlets to the sump?
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    May 2014
    I have a Dailey engineering 5 stage with an air oil separator so that 4 scavenge
    A williams performance pan with three scavenge ports in it and a petersons 7" drag oil tank
    Quote Originally Posted by tbscustoms View Post
    Same pump I have.. When I finish her up today I'll take some pics..
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    May 2014
    Kinda dead around here this time of year hahah
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Mine looks like an explosion at the Aeroquip plant
    QE 439 Twin Turbo
    Kent, WA
    Now that is funny !!!!!!
    May 2014
    Hahah that's what I'm trying to avoid
    New Port Richey, FL
    One example of what not to do.
    Didnt have time to plumb it up on the engine stand. Put this together using lines already made up. In the process of re-engineering the electrical system and tidy up the oil system. . 2 filters System 1 pressure filter and Oberg return filter. The turbos drain into the Oberg. Works out well it draws the oil from them.
    Tidy depends on where everything is located and how much room you have. That poor Oberg has 4 inlets and one outlet
Name:	Pressure filter.jpg
ID:	828249   Click image for larger version.
Name:	Return Oberg.jpg
ID:	828257   Click image for larger version.
Name:	Inlet manifold.jpg
    QE 439 Twin Turbo
    May 2014
    Default Dry Sump, Dailey Engineering.
    I want to put a dry sump on my 540. The one I really am leaning towards is the Dailey Engineering unit using their billet pan that has the pump attached right to it. I think this is the way to reduce the amount of plumbing, and so have less clutter with hoses and such. The only drawback is the price of the thing. It is quite pricey. Oh well, I have 6 months or so to save up for it.
    May 2014
    Ya Bill and I talked about using one of his pans and I really like the idea of it but at just south of 6k it was to rich for my blood
    waterloo
    I am a fan of lightweight lines for the suction sections. Obviously, they need to withstand the vacuum, negative pressure, whatever you want to call it.
    Just finished mine up.. Had to be a little creative due to the Sump I have..
Name:	12-24-2015 8-39-52 AM.jpg
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    '74 Sanger ski hydro the General's Avatar
    Dailey Engineering
    87 Kustom Kraft open bow cruiser jet
    84 Eliminator Daytona jet
    74 Sanger ski hydro v-drive
