Why would 1 side burn rich?
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 45
    Senior Member cave's Avatar
    Mesa, AZ
    Default Why would 1 side burn rich?
    Why would 1 side burn rich and the other side lean? I noticed on my transom a thick black soot on the right side and the left side was clean. I have through transome exhaust so its really visible. I pulled the plugs and all the plugs on the left side were lean and the right side plugs were black. 2 850 Holley DP on a 6/71 driven 8% under. I'm jetted 96 primary and 98 secondaries. Running 32° at the dizzy locked out. Burning Av Gas. I was at 94 primary and 96 secondaries. when I noticed the transom, I re jetted up after I saw the transom but it didn't make a difference.
    Pyro was at 1250° at 3500 to 5000 rpms and stayed pretty constant. That was on the lean side, # 1 piston.
    Anyone ever deal with this kind of situation?
    Takin it home
    What pv's are in the carbs? Have you tried "square" jetting all the way around?
    Mesa, AZ
    PVs are blocked off. I haven't tried to square them.
    Takin it home
    okie, lake Texoma
    Make sure that your intake is snugged up, might be sucking a tiny bit of oil on that side if she's loosened up on ya a little.
    Kingman/Golden Vly, Az
    if it were my set-up, i would put the carbs back to stock (acc pumps, pv's, jets)...IMO u have way too big of jets, they are bordering on alcohol jets!...i would then see how it ran...then, maybe bump them up a bit or square them...also, as was mentioned..ck the manifold for leaks...u should not be haveing that much trouble getting that motor to run rite! ...superchargering is not rocket science & u dont hear of any1 else haveing the kind of trouble ur haveing!!!! ...u need to re-acess the carb issue! or ur not gonna have any fun this summer!...just my .02 cents
    FastRat
    IMO the jets are not to big if the PV's are blocked off. Square jet (on the rich side) and let us know what happens. I think PV's are needed......
    You could always box them up and send them out to Nickerson or someone who can set them up. That way you just bolt on and set the idle.
    Mesa, AZ
    No biggy to go back to where I was last year Ron. I'll give it a few more runs. But so far I'm not impressed with the blown deal. I was faster before. Trouble free. Gas n go. I'm gunna cut the funds off for this deal soon. A few more items will be done then I'm done.
    I don't really know what others have gone through on there 1st go round with a blower set up. I don't know too many that boat like me. Every weekend, both days and some weekdays.
    Jay said he would work em for me and I'll call him Wednesday. Now that the get together is over I have some time for that.
    My old intake and worked Holley 950 DP is just sitting and waiting to get back on..
    Takin it home
    Cave, don't give up on it. Once you get it right, your gonna love it. My motors are ABSOLUTELY turn key. Hit the key and they fire instantly. All I do during the summer is check the oil. IMHO, it would be worth it to have the carbs set up by a professional, for a blower. Also, I would put some boost to that motor. Let the blower do what it's supposed to.I can't tell you what has been done to my carbs ( Merc racing), but I never have issues, ever. Infact, this boat has been one of the most reliable boats I have ever had. You still have time to dial her in before summer.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Cantard 71hallett's Avatar
    snow bank
    I would be looking past the carbs....once the fuel hits the rotors in the blower the motor doesnt know where its comming from square or not. My.02
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    HAY CAVE, I'VE GOT A SET OF 1000 CFM DEMON BLOWER CARBS YOU CAN BORROW TO HELP YOU TROUBLE SHOOT IT, IM NOT USING THEM RIGHT NOW, LET ME KNOW,
    I THINK I WILL BE IN GILBERT ON WENSDAY TO SEE THE KIDS
    YEA, WHAT 71 HALLET SAID
    two strokes is enough
    Yuma, Az
    Quote Originally Posted by FARMER JOHN View Post
    john got some stories to tell you about the weekend ill have to stop by this week. me and chris will be buffing his boat either tomorrow or wed swing by if your bored. check the pictures
    Sep 2008
    DOME VALLEY,AZ
    Quote Originally Posted by dp85tona View Post
    OKIE DOKIE
    New here Beer:30's Avatar
    Bakersfield, CA
    About the only way it could be one side is this or the gasket slipped during install.
    I can make jet changes on my 1050's/10:71 setup front to back and the plugs will read different on different cylinders. I would square jet because its easy to try it........
    I agree with Dmoore......throw some boost at it.
