Ignition Upgrade Question
Results 1 to 14 of 24
    Oct 2011
    Sandia,Tx. 78383
    Default Ignition Upgrade Question
    I've got a MSD -7ML2 ignition controller .Im converting over to E85 and wondering is the ML7 enough spark to make the Ethanol light properly ? If Not ? What would be the best upgrade and still keep my MSD Dizzy ?
    http://oathkeepers.org
    It'll be good.
    That's what I run with e85 and never had a problem.
    I replace the spark plugs after 3 or 4 years because it seemed like the thing to do.
    The old plugs still looked fine.
    Oct 2011
    Sandia,Tx. 78383
    Figured it would be , just checking before I drop some more coin on a new coil then find out later it's not gonna be hot enough
    The coil I've been using is the MSD 8252, the HVC BLASTER which MSD recommended.
    It says for use with the 6 series.
    I've been running it for a number of years and they may recommend something else now, but at the time I talked to them, the boat was N/A and would be used for occasional cruising.
    They make another coil that produced a somewhat stronger spark, but MSD recommended it be used only for DRAG RACING.
    The coil I use is certainly adequate for my engine and I turn it 7500-7700.
    I'd suggest contacting MSD for their recommendation if you don't get other opinions here.
    Senior Member poncho's Avatar
    SE Mass/Bering Sea
    Quote Originally Posted by Gopher711 View Post
    When I switched boats the old one had a 6 box and the new one was 7LM, I had the HVC-II (8253) and they said to use it, starts on the first crank and runs great.
    Dead Member Hyperpasta's Avatar
    Nov 2010
    Glendale, AZ
    Default Fyi
    Here's MSD coil compatibility chart. It makes life somewhat simple.
    http://www.msdignition.com/instructi...ompability.pdf
    Now If that's not good enough.....
    Summit has a comparison feature that you can compare a number of coil parameters, voltage, collapse time, resistance, etc. so no matter what you have for a CD box, the parameters of the coil are correct for the box you have...
    Seems that the wrong resistance coils will fry some components within the box over time. Seems coils vary greatly, so be aware of what you piece together. These boxes aren't getting any cheaper...
    Art
    Oct 2011
    Sandia,Tx. 78383
    Ordered the 8261 it's the recommended best coil for the 7 box I got
    Thanks !
    Thanks !
    Looks like an excellent choice of coils for the 7 box.
    How soon are you going to have that thing ready for the water, and are you Racing (sanctioned) or Playing?
    Oct 2011
    Sandia,Tx. 78383
    It will be race legal as far as SDBA rules , M/E class or faster ...I might buzz Marble Falls track if I get the bug just to see what it runs and get recorded on paper .
    main build was focused on being a quick lake Rod ...there's several guys that race in P/E class that still run the lake here ...just wanna hang with my homies !
    Are the P/E guys running jets?
    You certainly shouldn't have trouble running M/E or faster with what you have.
    I'll be interested in hearing how your ride turns out, and I think you'll not be disappointed using the e85.
    Outside of using a little more fuel and going a little faster, I don't think you'll find it much different from running gasoline.
    Remember, it's the same stuff that most new cars can burn.
    Oct 2011
    Sandia,Tx. 78383
    Two or three ,not that many ... Most have hydros , several more jet guys in M/E also on water
    i ran it in M/E class back in 2006 with shitty pump , no shoe setup and way less power ...so yes hopefully It will move out a little better now
    Iuka, Mississippi 38852
    Not running alcohol but 110 Sonoco. I use a MSD-7ML-2, #7561 launch controller, Power Pro coil and 5551 dist. in the 10 second class. It`ll throw nearly 2 inch HOT, KILLER spark. Any upgrades in my future won`t be the ignition.
    Senior Member bp298's Avatar
    LHC
    i believe I have a stone dude somewhere that says marble falls, m/e, 2006 on it...
    Nov 2010
    Default Pe 426
    Quote Originally Posted by Richard Till View Post
    Wow, with that hot killer spark your motor would run GREAT with NOS . You'd be running the 9.0s easy . Click image for larger version.
