MSD Crank Trigger???
Results 1 to 6 of 6
    Senior Member Chuck Wagon's Avatar
    Palm Desert
    Default MSD Crank Trigger???
    Going to be installing a MSD system on my 502 pump gas , when is necessary to install a Crank Trigger kit. Any pro or con or save my $. Thanks in advance
    anytime you want a more stable signal the crank trigger is the way to go.
    tell us more about the 502, blown? compression ?
    #55
    Palm Desert
    502, 9/1 compression afr 325 heads 850 carb installing a pro shot fogger, found a old thread discussing the crank trigger system sounds like he way to go.
    Lurker
    NC
    If you are going to spray it, a crank trigger is a wise investment.
    Palm Desert
    Thats what I've been reading. thanks
    Quote Originally Posted by 502 carrera View Post
    Having to space out all of your accessories is the only real draw back.
