Valve Springs
Valve Springs
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    Default Valve Springs
    What percentage of valve spring pressure can you lose before you consider them toast? I'm running a manley nextek 221454.
    290 on the seat and 850 over the nose. Boat sees about 8500 at the stripe. Don't have a problem replacing them just don't want to replace springs that are still considered acceptable.
    Tri-Cities, TN
    15% of seat pressure drop and you need to change them.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Quote Originally Posted by steele211 View Post
    300 lbs MIN @ 8500 RPMs
    waterloo
    Lift, and profile kinda matters.
    Wags
