Cam for 555" bbc
Results 1 to 14 of 17
Cam for 555" bbc
    Jmp
    Jmp is offline
    Junior Member Jmp's Avatar
    Nov 2014
    Default Cam for 555" bbc
    I have as Phaff 555" in my 28 eagleand am looking to replace the cam. The cam currently in the engine is different from the cam phaff put in it. I have a feeling that the current cam is hindering the performance. The engine is a std deck gm bow tie with a dart single plane intake manifold, dart aluminum heads and a 1050 dominator carb. I'm looking for a cam to replace the present one with that is more appropriate for the engine. Unfortunately I do not have the grind specs on the present cam but the dyno sheets I have from phaff show the engine make 680 hp at 500hp. I know this is probably a long shot but I'm looking for any help I can get.
    Quote Originally Posted by Jmp View Post
    Usually a dyno sheet will list engine specs, including cam specs. It's not on there? You can probably call Pfaff and see if they have records and can supply the same cam. You have a typo in your post, at what rpm did it make peak power?
    Jmp
    Jmp is offline
    Nov 2014
    The cam specs are not one the build sheet. Oops my bad, I meant 5000 rpm
    Get ahold of straub technologies or chris straub here, buy a cam built for your motor in your boat
    Jmp
    Jmp is offline
    Nov 2014
    Good mid range torque & HP, fair idle, performance usage, mild bracket racing, good w/manifold nitrous system, auto trans w/3000+ converter, marine appli- cations: for 454-502+ cu.in. modified engines in per- formance applications w/ aftermarket dry pipe exhaust systems. 3400-3800 cruise RPM, 10.0 to 11.5 compres- sion ratio advised. Good w/Roots supercharger, 15 lbs. max. boost w/8.0 max. compression ratio advised.
    ZHR-296-2S-12 IG
    2200- 139021*a 6000
    3
    13532-16b
    234 296 242 304
    112
    10 44 58 4
    .000 .610 .000 .632
    Here are the specs of the original cam that was in it on the Phaff Dyno.
    Placentia, CA
    What he said X1000!!!!!!!!!!!!!!!!!
    steveo143 AKA DiMarco 21 II
    Oct 2011
    Sandia,Tx. 78383
    Quote Originally Posted by steveo143 View Post
    What he said !
    Another Straub cammed motor here also !
    Straub has done mine and a few others down here , all with Excellent Results !
    http://oathkeepers.org
    Does that mean the cam you got from me in your 496 is not good?
    The Straub cam went in your 621 that has not run yet, I got the other turbo cam from my guy. His cams have never disappointed me and I have put together who knows how many engines with them.
    Senior Member TexasJet's Avatar
    College Station, Texas
    There's a Straub cam in this motor. I like it a lot and so did the engine builder.
    Anaheim Hills
    Quote Originally Posted by TexasJet View Post
    I need more cowbell!
    Feb 2009
    MANTECA
    Default Cam choice
    It doesn't matter who you choose to pick your cam but you are going to need to provide a little more information on the heads and possibly a flow sheet. You will also need to decide what your intentions are for the engine. Are you looking to make more power? Do you want to make the power at a different rpm? What's wrong with the cam that you have right now and what cam is in the engine now. You might be better off talking to the original builder and tell him what you would like the engine to do. The original builder should have a build sheet for the engine and with a build sheet he would have the information needed to pick the right cam.
    Good Luck.
    Oct 2011
    Sandia,Tx. 78383
    Quote Originally Posted by NiceGuyEddie View Post
    Straub Cammed 555
    https://www.facebook.com/duane.hydro...49716445290648
    Quote Originally Posted by bigdog View Post
    It doesn't matter who you choose to pick your cam ...
    Good Luck.
    It matters a lot.
    Feb 2009
    MANTECA
    Quote Originally Posted by scott foxwell View Post
    It matters a lot.
    I agree.........I should have said "No matter who you choose........they will need more information".
    The more information you can provide, the better the results will be. I don't think he could go wrong having Chris Straub pick a cam for his engine, but even Straub will need more information.
