[Question] Stud girdle for Dart Pro 1
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 47
    Senior Member Jetdream'n's Avatar
    Sep 2009
    Concord, NC
    Default Stud girdle for Dart Pro 1
    I am looking for recommendations on stud girdle set for DART BBC Pro 1 heads. I know the obvious answer is to go with Dart girdles but, I'm looking an inexpensive alternate opinion that aren't junk...
    Senior Member Heatseeker's Avatar
    San Joaquin County, CA
    Quote Originally Posted by Jetdream'n View Post
    I could be wrong, but I believe that you have to use Dart girdles. That's what I have and they weren't that expensive as I recall.
    I'm sure someone will be along soon to give the correct answer.
    Tri-Cities, TN
    We use Jomar for girdles and then I make a 12pt poly lock that goes with them.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    All stud girdles are junk.Shaft rockers are the answer.
    Sep 2009
    Concord, NC
    Quote Originally Posted by PCE680 View Post
    100% With you on that how ever, at this time the funds have me at stud rockers so, I got to make them work.
    Kent, WA
    Webster,,,
    Castro Valley, Ca.
    Webster,,,
    X2 ran Webster's on the 540 in my Lumina for years with no issues. Dart Pro 1's do have slightly different valve angles and require a dedicated girdle.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Senior Member Red Rocket's Avatar
    winchester, ca
    X2 on the Jomar. They make one that fits the dart pro1 real well. I just put a set on a motor I dynoed yesterday. Just make sure it is for the dart head and not Chevy head.
    They are?
    There are certainly a lot of extremely good running motors running junk stud girdles.
    Maybe you used the wrong junk girdles.
    Senior Member bp298's Avatar
    LHC
    They are?
    depends on what you consider "extremely good". stud rocker/girdles will work just fine up to a point. but if you pass that point, problems start occurring. the only way to avoid those problems, or minimize them, is to with a shaft system. stud mount systems have limits.
    OK, There's little doubt that shaft rocker arms are better, but they are a bit pricey when the cost / benefit factor is considered for many.
    It seems that saying stud girdles are junk is misleading, or at the very least an overstatement. IMO
    Emmett, Idaho
    3x's on the Webster girdles there made in Sacramento,ca.
    In fact some more of the ones I've seen offered by by some head manufacturers to compliment their heads are websters with head manufacturers name on them. I could be wrong...
    Stud girdles are just a bandaid for a poor design valve train by GM.
    Ada, Michigan
    For what it's worth,
    I have Dart Pro 1 heads and never ran a stud girdle,
    going on 16 years now. Motors a little above stock and I put many hundreds of hours on it.
    I've watched others pull the threads out of the heads with their shaft mount rockers.
