Priming an engine after sitting empty all winter?
Results 1 to 14 of 24
    Charlotte, NC.
    Default Priming an engine after sitting empty all winter?
    Do i need to worry about it? I pulled my motor 3 months ago and drained all the fluids while i worked on my enterior.. Im about to throw it back in the boat and fill it all back up. Should i take any special precautions?
    Kingman/Golden Vly, Az
    IMO, i would prime the motor to make sure the lifters & everything else has/gets oil...only takes a few minutes & better to be safe than sorry!
    FastRat
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    if it was me, i would prime it, why not, easy to do. I'm no expert, just my opinon.
    Charlotte, NC.
    excellent. thats what i needed to know...
    Now.. How does one prime the engine...? Im assuming you yank the dizzy and use a drill some how.. What i dont understand is how you engage that pump? is there a special tool?
    There is probably better ways but I'm lazy, I just unhook the the ign. wire and crank it until the oil pres. gauge moves.
    [email protected]
    Ohio
    And pull the plugs. That way theres no pressure on the bearings and it spins easier and faster.
    Delemorte You can make a tool out of an old dizzy. Just remove every thing on top, rotor, points/reluctor, advance mech, and put a hose clamp on it so the shaft doesn't fall out. Then put it in the engine, hook a drill to it and pump it up. I usually turn the engine over by hand as the drill spins the pump.
    Tim
    San Clemente, Ca
    Buy the tool, it's like $20 bucks max and you can find them cheaper than that. Pull the diz, slide the tool into the dizz hole and hook up your drill. Your oil pump shaft is spun by the distributor, this tool reaches down and grabs the oil pump shaft and spins it.
    I dont know about the whole pulling the plugs and ignition method. sure there's not alot of load on the main/rod bearings but still why... what about the cyl walls and the rings scrapin down them... And unless you have hyd lifters the pressure of the valve train is still pressin up against the valves, rockers, lifters and cam! I prime the shit out of mine, i can pretty much kill a cordless drill battery with a prime
    http://store.summitracing.com/partde...6&autoview=sku
    San Clemente, Ca
    Is this somthing you do after it sits a long time or before every use? This method sounds good for when you say havnt ran the engine in a few weeks just to ensure oil pressure at fire. How long before you see oil pressure when cranking?
    Don't make this more difficult than it is.....
    pull the plugs, disconnect the power to the distributor or battery side of coil and spin the engine over with the starter until you get oil pressure.
    because like River Rat said, the engine must be rotated while the oil is flowing. then you have to set the timing and if you have a ford
    you take the chance of dropping the oil pump drive
    #55
    I didnt know about the whole pulling the plugs and ignition method. sure there's not alot of load on the main/rod bearings but still why... what about the cyl walls and the rings scraping down them...
    if you do a normal winterizing of your boat/watercraft
    you would have pulled the plugs and squirted a little top end lube
    in the cylinders and rolled it over a few times already when you changed the oil and filter after the season.
    come spring time roll the engine over a few time to get oil pressure
    and install plugs, good to go...
    #55
    I like to see the gauge move before it fires if it's sat even overnight.
    San Clemente, Ca
    Whats this winter that you speak of You mean you dont run your boat all year round?
    Agree with you there, another good reason why i'm moving from a key'd ignition to a seperated switch system.
    San Clemente, Ca
    What? You guys aren't running one of these? Shame on you all!
    http://store.summitracing.com/partde...5&autoview=sku
    i always see those in the mags, just never seen one on anything
