BBC Gen4 Oil System
Results 1 to 7 of 7
BBC Gen4 Oil System
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    The oil priming thread has got me thinking.. i've though about this before, even did some quick googling but never really found anything. The oil system of a BBC is not somthing thats really talked about much here. Does anybody have pictures or diagrams of how the oil system on a BBC is setup. I would like to find out, where oil flows, how it flows, what areas get oil first, how the oil gets to those areas... basically discuess how every part gets oiled!
    Morgan Hill
    Super simple, rear main first, front cam bearing last, the oil galley is where it all takes place, there are holes all the way down the block and it "tree branches" off from the rear of the engine forward, the lifter bores get the leftovers from the cam bearings...Big block Ford are the exact opposite...
    edit: I guess to expand on it...pump pick up, pump, oil filter, rear main and rear cam bearing, then goes rods /lifters mains cam, rods /lifters and so on...
    GT
    GT
    I've always been confused, if the first place the oil goes on a mark iv motor, is into the mains/crank, how is that not considered a "mains priority oiling system?"
    How is a gen 5 or six different? And what mods(besides a better pan,dry sump) can be done to improve the mark 4? I've heard of pipe cleaners in the pushrods, is that worth while? I guess the idea there is less oil to the top means more to the bottom?
    Default Restrictors
    I use the restricters (.060) in the rear of the lifter galleries. (they take the place of the NPT plugs in the back of the motor) For balls out racing, they work. DO NOT use them with Hyd lifters, or engines that idle a lot...............Ray
    LOUD BOATS SAVE LIVES
    San Clemente, Ca
    Can you post pics?
    Can you post pics?
    X2 .. and what if you have hippos??
    Default Mail order
    Can you post pics?
    Look in Jegs or Summit catalogs under restrictors..........Ray
