Who's running a Launch Controller in your Jet ?
Results 1 to 14 of 16
    Oct 2011
    Sandia,Tx. 78383
    Default Who's running a Launch Controller in your Jet ?
    Looking at installing one of these soon , so what's the preferred deal ?
    http://oathkeepers.org
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by Gopher711 View Post
    We run a 4 channel digital spray timer. 2 channels control 2 retard timing maps, but we run a xdi2 ignition. 3rd controls the place diverter, 4th auxiliary pop off control. xdi-2 can be had for around 1700 wired and floating. The kit is around 1500, I think the timer was 400ish
    Alot of people run the msd grid. I gave up on msd 10 years ago.
    Oct 2011
    Sandia,Tx. 78383
    Damn that's a lot to control I'm just looking for some way to stab the throttle and let it ramp in the power without feathering the gas pedal
    Quote Originally Posted by piston in the wind View Post
    It wasn't that long ago the JET guys made fun of the flat drivers because of having to operate a down pedal.
    Dec 2010
    Sapulpa ok
    msd grid can do more.
    Dec 2010
    Sapulpa ok
    Wasn't me.
    Wasn't me.
    OOPS - I didn't mean you, just in general.
    Iuka, Mississippi 38852
    If you already have a box and can find one, an MSD 7561 works well. I run one with a 7 ML-2 set to 5,300 for 1.3 seconds, then WOT.
    Senior Member bp298's Avatar
    LHC
    msd digital 7 has a programmable launch controller, which is basically a programmable rev limiter. msd hasn't manufactured the standalone programmable launch controller for several years now. that one (which Richard is referring to) was very good. the first programmable launch controller was the banderlog, but that hasn't been around for a very long time. there were problems with that one. before the programmable deals, people ran 2-steps using msd chips and a timer. you can still piece together a 2 step, but you'd have to figure out what parts you wanted to use.
    go find a post -anywhere- that supports this accusation. whenever shit talking begins, it's always from flat guys. always.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    FAST ECU has everything a Grid can do built in.. Plus some.
    QE 439 Twin Turbo
    Dec 2010
    Sapulpa ok
    LOL good Stuff !! True stuff Though......The flat poke I mean...
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Can these be used at 'launch controls' with a mag?
    http://www.performanceboats.com/part...ntrollers.html
    Mar 2010
    Clarksville, TN
    Sounds like you need a better pump
    New Port Richey, FL
    Quote Originally Posted by ptc View Post
    I would guess you already know that answer.
    QE 439 Twin Turbo
