1050 dominator set up
Results 1 to 5 of 5
    Jmp
    Jmp is offline
    Junior Member Jmp's Avatar
    Nov 2014
    Default 1050 dominator set up
    I have a Holley list 8082-2 1050cfm 2 circuit dominator I am setting up for my 555" bbc. I am running 9.7-1 comp dart pro 1 345 cc heads, and edelbrock 2927 4500 series manifold. I'm looking for a good starting point to set the carb up for my pleasure boat 28' eliminator eagle application. I already went back to stock and 84 square jets with 6.5 pv's and the boat was running to lean. I jetted up to 92's square and pit in 37 squirters and it helped out quite a bit. Is anyone else running a single 8082-1 or-2 in a n/a engine?
    Thats the same carb I run. I ended up going to 4.5's on the pv one my deal. Had a wicked enough bog if you tried to flat foot it she would outright die.
    Jmp
    Jmp is offline
    Nov 2014
    What jets are you running?
    Quote Originally Posted by Jmp View Post
    83'S Ring a bell. I am not richer than stock jetting. I run at altitude and recall dropping a jet or 2.
    Are you sure you are lean.....I cant read plugs for chit. I ended up buying a wideband just for peace of mind.
    I assume you have checked for vac leaks.
    Jan 2010
    So Cal
    What makes you think it's still running lean?
