Jet Thrust angle help needed
Results 1 to 14 of 25
    Oct 2011
    Sandia,Tx. 78383
    Default Jet Thrust angle help needed
    You guys running the really quick and fast mph setups in 19' Daytonas , Liberators ,Cheyennes >
    taking the bottom of the keel / intake as say a flat plane and Measurement (A)
    Ride Plate angle up from intake ...as measurement (B)
    Nozzle angle ( up or down in relation to keel / intake as (C ) and size nozzle insert ? (D)
    im trying to get a close a starting point as possible on initial setup and some proven set points
    My parts ....MPD lowpro intake , Dominator 12S >full detailed pump , "A" stainless - HM inducer ,stuffer plate .... Place Mini Droop w/FTN nozzle inserts ( I have several sizes )
    And no , I'm not gonna put boat on circuit and race against anyone so your setup secrets are safe
    just PM me if you don't want to post here , Thanks Guys
    ps , should I get rid of Place diverter and run a fixed angle nozzle ? Or just put a manual stop of some sort on what I have once thrust angle is decided ?
    http://oathkeepers.org
    Senior Member Jetdream'n's Avatar
    Sep 2009
    Concord, NC
    Quote Originally Posted by Gopher711 View Post
    Think you need to transfer this question to the jet section...
    Oct 2011
    Sandia,Tx. 78383
    Quote Originally Posted by Jetdream'n View Post
    But all the really Smart guys are over here
    Senior Member bp298's Avatar
    LHC
    use the flat next to the shoe as your "zero reference" spot, like in this pic. using that as zero, everything else is referenced to it. for example, if you say your plate is 2 degrees up, it is 2 degrees up from the referenced zero point. same with nozzle angle or anything else. so if someone says the nozzle is 3 degrees up or 3 degrees down, you are speaking the same language as everyone else. if someone is suggesting a nozzle or plate setting, they assume you know it is referenced to this location.
    Sep 2009
    Concord, NC
    Quote Originally Posted by gopher711 View Post
    but all the really smart guys are over here
    lol.
    waterloo
    BP is an idiot.
    Crank the nozzle up until you have spray for 100 yards behind you!
    You are welcome for the tip.
    Wags
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    BP you might want to get some new glasses for the guy that machined your shoe. It's no where near square.
    QE 439 Twin Turbo
    Oct 2011
    Sandia,Tx. 78383
    BP is an idiot.
    Wags
    I tried that at a Marble Falls race many moons ago ,
    Guys on starting line behind me hastily pointed out in the pit area ....that this was NOT the way to do it
    Tower Park Resort, Lodi, CA
    I've found that having the nozzle at 180º from the direction I wanna go has worked well. But I don't race, so take it for what it's worth.
    Really depends on who did the keel. Its all grey when it comes to that.
    LHC
    naw, shoe's perfect. you might want to saw the bottoms off some coke bottles so you can see the pic correctly.
    BP is an idiot.
    Wags
    uhhuh. I see what you did there waggles. your trying to get me to tell you to GFY - YMIAW. but I'm not gonna do that because I'm just an all around nice guy...
    but I can install a starter without it wobbling all over the engine block... you are more than welcome
    Oct 2011
    Sandia,Tx. 78383
    Feel the love in here ! LOL
    anyways here she is ready for maiden voyage ....
    I've enjoyed your posts over the past year or so. Best of luck to you and your new beast
    Keep us posted
    Emmett, Idaho
    For best top speed, after the boat rolls over and on plane, raise roost till it is about 2 1/2 ft high (+/- 6 in). That should be in the ball park with out a radar gun.
