Silly question
Results 1 to 14 of 15
Silly question
    Member bennyb's Avatar
    Mission viejo,ca
    Default Silly question
    I have a dooley 14 qt pan in my eliminator, It has the dip stick opening in the pan. What are you guys using for your dip sticks. I put all this money in this engine and I can't seem to find anything other than cheap junk.
    Go on get your ass outa here
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    i had the same pan, i used a cheapo summit chrome one, i just cut it down a bit so it wasnt sticking way up above the valve covers.
    Think this was it.. worked fine, never had any problems with it...
    http://store.summitracing.com/partde...5&autoview=sku
    San Clemente, Ca
    oh, i did have to bend/roll it alittle bit to get it to clear the motor/headers and for it to line up to bolt to the block. was simple to do....
    I use one from LOKAR. It's made of braided stainless hose and is pretty flexible. Only problem I found is that it was a few inches too short to come up in front of the header like I wanted. In talking to their rep in Reno during Hot August Nights, he told me they could make one any length I wanted. I'm seriously considering doing that. Here's the web page for their dipsticks and tubes.
    Look no more, you can get them in any length, and put it any where you like.
    http://www.lokar.com/interior_pages/engdipstick.htm
    Newton Ks.
    Used one of those when I went from logs to Lightnings, and I like it.
    It would be nice if it was an inch or 2 longer to see, but, if it was, it'd be even more of a pain to use due to the back of my back seats getting in the way more, so I like it as is.
    H.L. Mencken
    Default Screw in
    Quote Originally Posted by Eliminator Cruiser View Post
    What is wrong with the Dooley screw in type?..There should be a threaded tube sticking up from the kick out....You do have a kick out, right?....Ray
    LOUD BOATS SAVE LIVES
    My Dooley 14qt only has the stock-style dipstick tube fitting. Nothing on the kickouts.
    San Clemente, Ca
    Either did mine...
    I just bought the stefs/B&B pan, was thinking about tapping the pickup and just plugging it. Maybei'll get one of those fancy braided deals
    Mission viejo,ca
    Ditto...
    Default Custom
    Well it looks like its "custom fabrication" time. Those braided deals look cool, as well as the chrome tube deals if you bend them, form them, shorten them, and then calibrate the oil level the first time you fill it. (or on the garage floor prior to installation). I used the chrome tube deal on the jet boat 25 years ago, and it still works/ looks fine, IMO..............Ray
    We plug ours using JB Weld. No need for a dip stick on a high performance/racing engine. With 14 qts oil, you can't burn/leak enough to cause a lubrication problem without seeing it somewhere else. Also, most of the dipsticks leak, making crankcase sealing a problem if you run a pan evac or vacuum pump.
    San Clemente, Ca
    I though about doing this, the only thing i really ever used my dipstick for was seeing/smelling/feel the oil. Well not using jb weld, though about taping it for a plug.
    Fresyes
    x3.. And they have double o-rings. My old cheapy leaked as well. Lokar has been dry as a bone. I little annoying to add oil through (they include a fitting to make it easier), but worth the hassle to 1-- looks cool and 2--Doesn't leak.
    Is it just me or are toilet seats getting smaller?
