Gen V timing set
Gen V timing set
    now what?
    Lake Travis
    Default Gen V timing set
    Will Gen Vi timing set work on a Gen 5? Serached around and havent found a definite
    answer on if timing set is different from Gen 5 to the other years?
    If it makes you say DAMN it must be a CARRERA
    1984 Carrera 32' raceboat
    1988 Carrera SS8M
    Quote Originally Posted by HTRDLNCN View Post
    Yes, if you are using the Gen 5/6 style cam with the step nose. You can also use a MK IV style cam (with MK IV timing set), but you will need an aftermarket timing cover to clear a double roller chain set.
    now what?
    Lake Travis
    Its a Mercruiser 454 mag Gen 5 with flat tappet cam..
    Seeing as its flat tappet I would guess it is a gen4 style cam or did they step the nose on those as well?
    Thanks for info..
    1988 Carrera SS8M
    Tri-Cities, TN
    Thanks for info..
    No stepped face flat tappets, only rollers. A mark 4 timing set will work in a Gen5/6. A Gen 6 will work in a mark 4 with the retaining plate.
    Note, 1 out of every 10 Gen5/6 builds the rollmaster set we sell contacts the block. I have heard the cloyes set as well does this. Always mock it up and check it before assembly.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
