Blower size/PSI?
Results 1 to 7 of 7
Blower size/PSI?
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    Default Blower size/PSI?
    I have a question about size's of blowers.
    If you have a blower like 871 and it put's out 6PSI does a larger blower put out more PSI at the same speed?
    I know the larger blower put's out more cubic inches of air but not under standing something.
    I see that some people put huge blowers on small cubic inch motors but does that mean that they don't have the Boost or PSI of a smaller blower?
    I hope that makes scene.
    Thanks Troy
    Quote Originally Posted by APOLLO View Post
    Thanks Troy
    YES. more air is being driven (forced) at the same drive ratio into the engine..boost will go up
    It will also be at a lower temp.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    MAHTOMEDI,MN
    I remember that now. Thanks guys
    Mr. Potato Head
    IN DA U.P. EH
    You thinking of cutting a hole Troy?
    76 COLE TR2
    MAHTOMEDI,MN
    It's off and not going back on LOL And it's on like donkey Kong
    Senior Member Jake's Avatar
    Blower size is most correctly determined by cubic inches.
    the more inches the more blower.
    the more blower the more horsepower to drive the blower
    the faster you spin it the hotter the charge
    the bigger the blower the slower you can spin it
    All these issues should be taken into consideration before selecting a blower size to maximize the blower and motors efficiency.
