Dan Olson Oil Cooler Pros and Cons?
Results 1 to 11 of 11
    Gone in a Flash! Speed of Heat's Avatar
    Lake Pend Oreille, Idaho
    Default Dan Olson Oil Cooler Pros and Cons?
    Can anyone comment on experience with Dan Olson BBC block mounted oil cooler? I have one I was planning on using for a new build. I see a large number of them for sale, so I'm wondering if there is any issues with them other than making sure there real clean? Leak prone?
    Remember that the Ark was built by amateurs and the Titanic was built by professionals.
    Quote Originally Posted by Speed of Heat View Post
    They work fine. I ran one on the turbo engine in my Schiada. Go ahead and get the o-ring kit for it and open it up. Mark the orientation of the end cap so the fitting will face the correct direction when you re-assemble it. Then you can inspect the core to make sure it's clean, as well as checking both end caps to make sure there is not too much corrosion that would cause the large o-rings not to seal, or even get thin enough that the caps could leak water through the aluminum.
    OK, Thanks for the response Barry. Cooler seems like a nice piece of hardware. I just been kinda bit leery seeing how many I see for sale.
    Senior Member Mr. Denton's Avatar
    Jun 2014
    I know mine takes about 40* of heat out of my oil. Mine is also force fed water.
    Using Tapatalk
    Kent, WA
    How hot is too hot for your oil ?
    Oct 2011
    Sandia,Tx. 78383
    Another tidbit to consider if it is block mounted is ....space ...do you have enough room for one ?
    they are not exactly small coolers
    http://oathkeepers.org
    Space not a problem- Cavernous bilge -Sanger Mini V-drive Cruiser... Tuna Boat
    Right, I removed the Olson cooler on my 21' Howard because the oil hardly got hot enough, unless I ran it flat out a couple of times in succession.
    General consensus (at least in my field) for "normal" dinosaur oil is 250*F in the sump as a good high end limit.....I like to target operating temp around 210*F so it boils the moisture out of the oil.
    Nov 2009
    Jerome, Idaho
    I run a remote Dan Olson with my ford flatty. I run the hot water out of the engine and put it through the inlet on the oil cooler, thus oil temp comes up easier!
    Member Connolly Marine's Avatar
    Feb 2014
    Lake Havasu City
    If you need the end caps or o-ring set, we stock them
    Dan Olson Racing Products
    High Performance Marine Hardware - V-Drive - Jet Drive
    Order online @ www.connollymarine.com
