HVC II Coils
Results 1 to 14 of 16
HVC II Coils
    Default HVC II Coils
    Any thoughts on using the MSD HVC II Coils? I'm looking to upgrade the
    MSD system a little.
    GN7 Correct you are, the MSD 8252, is what I meant to post up. Good stuff Eh? The SS does not lay out right for my application, the 8252 does the trick. Just the price is a bit lofty, so I wanted to make sure is a good piece.
    Rancho Cordova. CA
    I am running the HVC II with a digital 6. Done it for 2 seasons so far.
    Haven't had any problems.
    There are 2 HVC II coils, the "Blaster HVC II" http://store.summitracing.com/largei...g=msd-8253.jpg,
    and the HVC II
    http://store.summitracing.com/largei...g=msd-8261.jpg
    The 8621 HVC II isn't recommended for the 6 box. I'v been running the 8252 since 2002.
    Rancho Cordova. CA
    I have the Blaster HVC II. I guess I am good.
    The HVC II is for the MSD 7, don't use it if your running a 6A or 6AL, use this
    the 8252, it's virtually indestructable
    http://www.jegs.com/webapp/wcs/store...-1&showValue=3
    or this
    Whats the difference with the red and blue coils? I have been running the red one but the blue one would look better on my Blue boat
    G H E T T O F O E L I F E
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I run the blaster 2 coil (the round cheaper one) right now with my 6AL setup, i asked about coils a while back never got a great responce. Whats the advantage to these expensive ones over the blaster II? Is it that big of a difference?
    The round can type oil filled deals can shake them selfs to death in a boat. The E-core type coils will take vibration much better than even the epoxy filled cans.
    will the 8252 light off what a basic oil filled blaster 2 won't? i'm shopping for a hotter coil for the twin turbo bit, cylinder pressure is gonna get up there pretty high and i doubt a blaster 2 is gonna light it off.
    I don'tbelievethere is a significant difference between any of the coils for a given box. Seems some trade spark duration for current, or voltage for current. If you need more power, you need to step up to a 7, 7digital or even a 10.
    i would think giving up duration for more current would get us there if there's a coil that'll do that with the 6mbtm box(6al with built in btm).its not like we'll need 20 sparks under 3500rpms, just 1 hot mofo at 7500rpms will suffice
    if you read the spec for each coil MSD lists the cureent, voltage, and duration of each coil. I believe thats the idea behind the HVC stuff.
