Curious what guys think this 468 makes h/p ??
Results 1 to 13 of 13
    Jul 2010
    Default Curious what guys think this 468 makes h/p ??
    I DIDNT BUILT IT I BOUGHT LAST JULY NOW I HAVE THE ENGINE OUT OF THE BOAT SHORT BLOCK STILL TOGATHER MIGHT BE CHANGING IMPELER CAUSE SHES ONLY SPINNING 5000 RPMS ITS A 19' DAYTONA ELIMNATOR WITH AMERICAN TURBINE A/B STAINLESS IMPLELLER ....10 1/4 POP UP PISTONS CAM IS SOLID FLAT TAPPET
    • Advertised Duration (Int/Exh): 316/326
    • Duration @ .050 (Int/Exh): 261/271
    • Gross Valve Lift (Int/Exh): .608/.638
    • LSA/ICL: 110/107
    • Valve Lash (Int/Exh): .022/.024
    • RPM Range: 3800-7500..... HEADS O49 CASTING 122CC TUNNEL RAM WITH 750S IM THINKING 450 H/P ?? CURIOUS TO WHAT YOU GUYS THINK ? THANK YOU I MIGHT CHANGE THE CAM TO THIS NOT SURE THOUGH
    • Advertised Duration (Int/Exh): 276/282
    • Duration @ .050 (Int/Exh): 241/249
    • Gross Valve Lift (Int/Exh): .590/.610
    • LSA/ICL: 110/106
    • Valve Lash (Int/Exh): .018/.018
    • RPM Range: 2600-6800
    • Includes: Cam & Lifters (#70992-16)
    Both cams are too big for the A/B impeller and pump gas compression, in my opinion. If you are only turning 5,000 rpm, you don't need a cam that will run 7000 rpm. If you have looked on jet pump hp/impeller charts, it will give you a good idea of what your engine makes at 5,000, since that is what you are able to turn, however the engine does not have enough grunt to get past that threshold to turn the higher rpm the cam was designed for.
    The other primary concerns in selecting the right cam for your combination are, have the heads been ported, what exhaust do you have, and details about the boat, including size and intended usage.
    Jul 2010
    haeds have not been ported have basset twistys wet headers 19' daytona elimnator pleasure river boat
    Just my o2. 580 to 600 less than 250 at 50. On a 112 installed at 110
    Whitewright, TX
    I agree, my first thought was the cam is waaaay to big. Here's the chart Barry is referring to. Jocko
    Whitewright, TX
    Your guess of 450 HP pretty close! Jocko
    According to the old JPCalculator, using either the AT or Berkeley data, 5000rpm on an A/B cut is only about 365HP at that rpm.
    Jul 2010
    yea i just read that .............. intresting !!
    Quote Originally Posted by duty View Post
    fwiw. with that combo in a cruiser I would look at something about a .520lift. 232- 238 duration and if you are looking for a pretty sounding idle about a 109 lobe center. in my opinion you are doing what alot do, over camming and wishing for more. Just don't do it. what alot do is overlooking the valve springs. The valve springs are the engines built in rev limiter. JMLAO M
    Jul 2010
    i did not build this motor it came with the boat it had 049 heads on it i have in basement 990 rectangler port heads i can use but been told those heads dont start working till 5000 rpms then i know a guy that selling brand new complete pro comp rectangler 320 cc heads for $1000 any suggestions ??
    what are your'e expectations of the boat? 049 heads are good to flow for a smaller inch BBC up to about 6k but without knowing more it's guess work. I have ran 049" and 990" and both serve a purpose. You could save a grand and stick with the 049" and maybe still be at what you want. With a proper valve spring and Cam. Again it's about what you want out of the boat. M.O. Mark
    Rancho Cordova. CA
    I can give you a great example of "production" heads that work on a BBC. I am running a 496 (4.310 bore 4.25 stroke) I have 702 casting heads (396 closed chamber heads at 96cc) It is 10.2 to 1 with flat tops. Has a tunnel ram with 2 450cfm carbs. Cam is 244/[email protected] 113LSA 570 lift. It spins a Berk A with a stage 1 blueprint to 5500rpm and pushes a heavy 20.5 Carrera Eclipse jet to 80mph. I bet the o49's might flow better than the heads am using. Save your money!!! Just my lame azz opinion
    Quote Originally Posted by carreradude View Post
    i can give you a great example of "production" heads that work on a bbc. I am running a 496 (4.310 bore 4.25 stroke) i have 702 casting heads (396 closed chamber heads at 96cc) it is 10.2 to 1 with flat tops. Has a tunnel ram with 2 450cfm carbs. Cam is 244/[email protected] 113lsa 570 lift. It spins a berk a with a stage 1 blueprint to 5500rpm and pushes a heavy 20.5 carrera eclipse jet to 80mph. I bet the o49's might flow better than the heads am using. Save your money!!! Just my lame azz opinion
    good advice!!!!!!!!
