Carb Rebuild recommendations needed
Results 1 to 13 of 13
    Anaheim Hills
    Default Carb Rebuild recommendations needed
    Looking for a carb rebuild shop in or around OC. Thanks.
    Senior Member Sanger-Spectra's Avatar
    May 2010
    Default C&J
    C & J Engineering in Santa Fe Springs right at Valley View and the 5 fwy. 562-229-0222. They did mine a few years back, all I had to do was turn the idle a 1/4 down other than that the carb was perfect.
    Quote Originally Posted by NiceGuyEddie View Post
    Whats the problem?
    Anaheim Hills
    Quote Originally Posted by Sanger-Spectra View Post
    Thanks.
    I called them. While I have heard a lot of great things about that shop, I'm going to pass. When I called to inquire, I wasn't impressed with the person's attitude over the phone. My have been a one time thing, but I don't care. Be nice to potential customers.
    Whats the problem?
    I need a Holley rebuilt. It sat for a awhile, so when I ran it, it ran rich and terrible. I want it completely gone through. No crazy race application or anything.
    Thanks.
    do you know anything about the internals of the carb. power valves and current jetting also floats and squirters. reason for questions it could be a simple fix and low dollar. I would be more than happy to take a look at it and check the carb out. Mark
    Apr 2010
    Rocklin, Calif.
    Thanks.
    Yep..me to
    John Avery 626-337-4614
    Dan Davinci 281-964-7782
    Both Top Notch and friendy
    Anaheim Hills
    Thanks for the offer. I don't off hand know any real specs other than it's a Marine Holley 750, 4 barrel. Electric choke, vacuum secondary. It feeds an Indmar 502.
    I checked the float level on the water, it was good. When looking into the carb while pushing throttle, fuel sprays inconsistently from the squirter. It was pinging, popping and blowing a lil black smoke on the water. I cruised it at 3500RPM for about 15 seconds, killed the engine, then pulled a spark plug to inspect. It's clearly running very rich. It's leaking a little fuel too. I'd like to have the surfaces machined, have it all gone through then ran on an engine before I take it back to the river and put it back on my boat.
    Thank you.
    Emmett, Idaho
    Ron @ performance carb in Ontario Ca.
    Jun 2011
    Default Carb
    Check needle and seat or power valve. Might be an easy 10 minute fix.
    Senior Member Futs's Avatar
    Orange CA, Big River
    C&J engineering is the best around. Good customer support and fast turn around.
    14130 E. Alondra Blvd. Suite J. Santa Fe Springs, Ca 90670 (562) 229-0222
    Thank you.
    it's not to hard figure out that you have gasket issues and power valves that are blown.A simple kit will cure most of these BUT it may need a jet change and squirter adjustment. It's bleeding fuel and probably air in all the wrong places. JMLAO. M
    Senior Member jdekruyf's Avatar
    Jun 2011
    Artesia, CA
    Thanks.
    I know what you mean but you won't regret bringing it by. Phones aren't everyone's thing. Guy was super nice and extremely helpful. Did both of mine and they were perfect
    Feb 2012
    Second on PC my stage 2 dominator works bitching!
