Head gasket question
    Senior Member Heatseeker's Avatar
    San Joaquin County, CA
    Default Head gasket question
    I need to hear from the experts here.
    I'm assembling my blown BBC. I'm running Dart Pro 1 heads. When I ordered my head gaskets(cosmetic 4.310 bore, .040 thick), I chose the set made for Brodix heads by mistake. I didn't scroll all the way through the notes on the page. I know, I'm a idiot!
    The only difference, which I didn't even notice until one side was torqued down and the other side was sprayed with copper coat, is the water passages on the ends of the gaskets.
    Is this restriction going to be detrimental in a blown lake jet or should I run them?
    Colfax, Ca
    Call Cometic
    Is this real or the "Twilight Zone"?
    May 2014
    Is that a mls head gasket ? Id also ask about the copper spray I think they are soposed to be installed clean and dry
    Cosmetic told me to take the head gaskets off and punch a couple of holes in the area to compensate. And I have used cosmetics with copper coat several times with no issues.
