100 over 1/2 fill the block?
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 53
    The Right Coast/SE-PA
    Question 100 over 1/2 fill the block?
    Mark-4 block, considering to bore 100 over w/4.25 stroke = 505ci
    Just asking, is there any reason for a river/lake runner not to fill to the water pump line or lower or...not at all?
    For a 1/4 mile burner I wouldn't question filling the block but, I'm not sure cooling or other issues could be a factor in how I use my boat.
    (Rex bypass T-stat used, usually see 160 +- 5 current block water psi usually 8 lbs)
    As always, thanks for any feedback.
    Water temp will only be slightly effected, but oil temp will change.
    And the need for a oil cooler >which I probably would have added for this build, for sustained runs down the river. Also concerned if water pressure when using my REX T-stat could be a issue too. I know water doesn't compress but less area to hold water may cause a higher pressure spikes???
    Thanks for the feedback
    i built basically the same shortblock but with 13.5 to 1 pistons to make a 505 and ran a 450hp shot of nitrous to it without a half fill, never a sign of cap walk.thought about it but i was cutting weight where i could, filler is heavy.we did half fill this twin turbo 496 we're building but it'll get a oil cooler , turbos alone will do a number on oil temps i'm sure
    waterloo
    How about not boring it .100 over, sacrificing the 15 cubic inches, and saving 60 pounds of weight.
    The real advantage is the stroke advantage, the 15 inches or so will not make two hoots in hell in a river boat.
    Just a thought.
    Wags
    Taking a block to the max overbore has always been a pet peeve of mine. In class racing, sure. In pleasure, even bracket drag stuff...why?
    I always think the guys that bore a new dart block to 4.6 are fools. If you really need the extra cubic inches, do it in stroke. The lever advantage will gain much more.
    BTW, I practice what I preach. I got a new dart block for the PE boat and just made it a 4.280 bore. Sure, I am sacrificing a little airflow. That is what the blower is for. It will last me until I quit drag racing. Blow it up, quit again, etc. I could then take it to 4.5 and it be a perfect piece, and still have value. Power is not a problem with a blown PE piece.
    Tri-Cities, TN
    Just a thought.
    Wags
    I agree, from a 496 to 505 your gaining 9 CID. A bada$$ engine makes 2HP per cube so at that your gaining 18HP. To me its not worth the weight nor piece of mind.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Thumbs up
    Nuff said, and as usual...great feedback!
    My current hole .060 is a little sloppy to reuse so, a .070 over slug it will have to be .
    Avondale,AZ.
    Unless core shifted, any 70s or early 80s BBC will go .125"+ without fill. ANY fill will increase oil temp because the bottom of the cylinders are a great oil heat sink. Much larger in area than most oil coolers if you factor the main caps and everything in the bottom end runs cooler than the oil unless filled. The cubic inch diference is not the main issue in gaining performance, the valve unshrouding is. Notice that the chamber is wider than the cylinder under the valves. We notch this area to just above the ring travel to aid in flow. Many BBC larger heads will not flow any more cfm ON AN ENGINE with a 4.280 bore than smaller heads! Back to the question: bore it to 4.375 and bore notch the deck, don't fill it at all. Sonic check the block if you are paranoid, and remember that we have taken these blocks to 4.400 on a regular basis, so the cubic inch gain is larger and at .125 you still have bore left to go. BBC blocks are cheap, why worry about the max bore?
    Mine is not the only valid opinion. The above is solely MY opinion based on 38+ years in the business, we are still here. Make yourself happy... TIMINATOR
    Quote Originally Posted by TIMINATOR View Post
    if it passes sonic testing, 505 sure has a better ring to it than a 496 i wanted 500+ cubes when i built mine and i used a block that had plenty of meat left over at 100 over.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    ole mans is a 505 alsowe have also seen 125 overbore on other boat mills before.not a problem and im with tom i like 505 better than 496,lol!!!!
    Why not build a 496 and lie come on, you know all of you have told bigger ones than that. Does anyone know what the weight diff is between block fill and the water it replaced. Bet it's not much.
    water weighs 7lbs a gallon and shipped weight of 4 empty moroso gallon jugs/shipping box weighed 40lbs. you fill the gallon jugs up so i'd say it took 3.6 gallons at 7lbs a gallon plus the 40lbs of filler it took to half fill the twin turbo 496 block 2wks ago.
    I seriouly doubt those jugs weigh 10lbs, a whole bag of that stuff only weighs 50, never the less, don't count the water you put in it, it's not there after it sets up. The weight in your block is the same as dry in the jug
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    why take any more life from the block then u have to??? I just went from 60 to 70 on my deal.
