[Question] Blower base gasket
Results 1 to 14 of 16
Blower base gasket
    Senior Member Johnny2bad's Avatar
    Sep 2009
    Land of 10,000 lakes
    Default Blower base gasket
    First timer installing a supercharger.
    Install gasket dry, oiled, glued to one side?
    Johnny
    Posted from my Etch A Sketch
    Senior Member TexasJet's Avatar
    College Station, Texas
    Dry
    The member 1bdhondo's Avatar
    ca
    Quote Originally Posted by Johnny2bad View Post
    Dry or I like to put a very light thin thin film of grease on both sides. If you have to take it off or will help and also I was told helps the gasket seal a bit. When I say thin I mean put on with your fingers and almost nothing but residue.
    Whitewright, TX
    DRY.....no need to put ANY sealant on a blower gasket! Old Guy tip tho.....sprinkle a little baby powder on both sides of the gasket, spread it evenly with your fingers....and the gasket will never stick for the next blower removal. JMO, Jocko
    good tip! M
    Sep 2009
    Thanks for the tip, who'da thought......baby powder, an outdoor summer workers best friend.
    Hmmmm, does the brand matter?
    LMAO
    Johnny
    Oct 2011
    Sandia,Tx. 78383
    I've sprayed them and carb base gaskets with the Gray dry Graphite lube to keep them from sticking also
    http://oathkeepers.org
    May 2014
    X2 on the baby powder had an old guy show me that years ago best trick out there....
    I like to uses lavender baby powder hahaha
    Emmett, Idaho
    Mill the manifold for o-ring, you can by o-ring material by the foot from grainger.
    Whitewright, TX
    Yep, THAT is the best way to go! No more fuel saturated gaskets. Jocko
    waterloo
    a) how much do you take the blower off... and why
    b) fuck, they cost 20 bucks.
    Jesus... I will send you one.
    Put the fucker on dry.
    Torque to 10 to 15 ft/lbs.
    Run for 20 years.
    Wags
    Sep 2009
    Run for 20 years.
    Wags
    Thanks for the offer, I'll take you up on that.
    I just cut one out of a glossy US Boat catalog cover.
    Johnny
    Sep 2010
    Plus with the o-ring you can R and R it and not have to find a gasket.
    GD
    waterloo
    Funny stuff.
    Wags
