coated pistons
Results 1 to 14 of 34
coated pistons
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    Default coated pistons
    What Are The Pro's And Con's With Coated Pistons? What Do You Gain Or Don't Gain?
    Thanks In Advanced Troy
    tops help retain heat in the chamber where it can help with power, helps keep heat off the pin if you are using a high placed pin, helps reduce the heat the alumn sees, specially during detenation, helps spred the heat across the entire surface instead of concentrated in local areas, etc. Basically every thing below the coating runs cooler. The skirt dry film can reduce wear but mainly safe gards against scuffing, specially on 2618 alloy pistons. There is zero disadvantage to coated pistons other than $$$$$
    MAHTOMEDI,MN
    Thank you very much
    Anaheim Hills
    They will also provide protection from metal shavings/debris. Thanks to my pistons being coated, I didnt have to buy new ones. The coating took the abuse.
    MAHTOMEDI,MN
    I heard of it before but never thought It would benefit me. I just got my pistons today and there was a brochure on piston coatings. That is why I brought it up. Now I'm thinking of sending them back to get coated.
    Thanks for the in put guy's
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    I went with coated piston skirts and coated main and rod bearings.
    Swain technologies, only because they are close to me (20 miles) and have been doing it since day one.
    Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    Cantard 71hallett's Avatar
    snow bank
    Quote Originally Posted by Jim W View Post
    Jim
    What do they charge to do pistons Jim...might send you a set.
    MAHTOMEDI,MN
    What kind of coating is it and is it the same that gets used on the rod and main bearings?
    No- bearings get different coatings. There are so many different types of coatings, it is crazy.
    Every time you coat an engine part that reduces heat absorption, you require less fuel to make a perfect burn. (Enter the discussions in NASCAR about different teams with different fuel economies.)
    Lurker
    NC
    Lightbulb
    Have never seen a performance advantage in any piston coating, and have seen them tested under very controlled conditions.
    There may be some longevity benefits from thermal coating the tops, and some combo's won't live without anodized top ring lands, but skirt coating is a waste of time. IMO
    Paul,
    the invoice from my machinist says $240.00 skirts only.
    He may of marked it up a bit for his time etc.
    Jim
    GN7
    Skirt coating may be a waste of time for performance but how about longevity when the piston needs a little help from being too tight for a unforseen reason?
    Jim
    GN7
    Jim
    Just curious what "unforseen reason" that would be?
    snow bank
    The unforeseen one.
    Did you hear anything back? Pm me if you did I guess.
