Exhaust valves
Results 1 to 14 of 16
Exhaust valves
    Default Exhaust valves
    In reading on this forum and online it seems like just about everybody says to either use Manley inconel or ferrea super alloy. I also read that ferrea is half the cost, but I'm either looking in the wrong place or things have changed as everywhere I have looked they are 45/50 dollars each. Is there anything else by other company's that are just as strong? I'm running n/a aluminum heads but there's always the possibility of a small blower at some point.
    Quote Originally Posted by nos1967 View Post
    Which heads do you have now, I thought you were talking 049 iron heads?
    I decided to sell my 990's that I had built last year and got some bare oval port aluminum heads. I know I'm going to get a lot of crap but they are speedmaster. My neighbor worked for an engine shop and has never had a problem with them. For 650$ a pair I couldn't find any used name brand iron or aluminum heads for that price. I have all the hardware but valves and I'm having a shop inspect and install everything on them.
    Senior Member Futs's Avatar
    Orange CA, Big River
    I just bought some ferrea super alloy for my AFR;s for 37 bucks each from Dakota. ask for Brian 605 388-3396
    I even got the super light ones. they weighed 131 grams vrs the 164 gram stainless valves that were in the heads from AFR.
    Sacramento area
    Check with Tony Mamo (661) 295-9587
    I guess what I'm really wondering is if the super alloy or inconel are really necessary for a 500-550hp jet boat engine running 5500rpm max. Some people seem confused as to why I want to run such an expensive valve in a mild bbc, while others say it's the only way to go...
    Well I ran the stainless ex valves in mine for years with no problems. even sprayed it with a 300 shot. I upgraded because piece of mind and I want to put a bigger shot on it. Your deal should be fine with a good stainless ex valve. are you running dry headers or water? if you get any reversion and have a water dibblet come into contact with a hot ex valve your asking for problems. A valve failure is one of the most destructive things that can happen to an engine. Its your money and your piece of mind, so if you want them get them.
    waterloo
    NO
    Wags
    Running logs, but I'm changing cams and getting one with reversion in mind.
    Futs makes a good point. The presence of water is always an issue with wet exhaust and another good reason to run a high temp alloy ex valve in a marine engine.
    waterloo
    Running bad ass valves is a band aid. Fix the reversion issue. Then piss off 4x the money for valves if it makes you feel good.
    Just my .02.
    Wags
    The cam I chose should have zero issues with reversion. 112 and 235 @ .050. I decided to go with stainless valves and spend the money on a roller setup.
    Senior Member fastnlight's Avatar
    Dec 2012
    Ventura
    Interesting reading material on valves. FYI only.
    http://www.enginebuildermag.com/2016...ves-and-seats/
    Senior Member andyc's Avatar
    Feb 2010
    Valley of the Winds
    Default hey Schick
    Is that Tony at C.H.E. ??
