Blower Set Up
Results 1 to 6 of 6
Blower Set Up
    [email protected] After You 362's Avatar
    California
    Default Blower Set Up
    What are the differences between a blower that is set up for alcohol and one for gas. My guess was that the tolerances on an alcohol blower could be closer due to the cooling effect of the fuel.
    Just curious...
    Joey
    Gone
    Sparks, Nevada
    Correct. Set up tighter.
    Emmett, Idaho
    usualy alky blowers are hard anodized inside.
    waterloo
    Most anything that is not a strictly pleasure, non high boost thing is anodized.
    Gas looser...yes....heat reasons as above.
    A gas piece after run..you can cook an egg on the case. An alcohol piece is nice and cool...hence clearance differences.
    Wags
    California
    Thanks guys, appreciate the feedback.
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    Joe,
    You chasing Denis ????????????????????
    Anyone can pedal a bicycle, can you pedal a flat?????
