Straub Tech LS rocker arm bushing kit
Results 1 to 14 of 21
    Tower Park Resort, Lodi, CA
    Default Straub Tech LS rocker arm bushing kit
    When I looked into a kit like this last year, the price was outrageous. Just stumbled across this kit offered by Straub Tech. at a price I can swallow.
    LS bushing trunnion kits - Straub Technologies
    From memory, the other kit I was drooling over used Bronze bushings with "self lubricating" properties. I'm curious and would like to know a little more about the "proprietary bushing material" used in the kit offered by Straub Tech. Features and benefits of the material? How does it compare to bronze?
    I understand why the solid roller cam guys would need the kit but never understood why hyd guys were. I saw 1 fail since 1999 when the silverado came out, including all the yrs i worked for dealers. I ran 150 seat and 400 open on the last deal with ls7 lifters on a xr lobed cam and never had any failures and that motor saw 7200 everytime i took it to water
    All of what you said is why I didn't do the caged bearing upgrade in the first place.
    Beyond that, for it's particular purpose, bushings just make more sense to me than roller bearings.
    If I upgrade, I'll choose bushings over caged roller.
    Ultimately, I suppose it's simply just a peace of mind thing.
    Tri-Cities, TN
    We started these last Summer and released them at PRI. The response has left me speechless. We estimated 2000 kits for the year, we around 2500 sold so far.
    We knew there was some wear issues with the aftermarket needle kits and when the OEM rockers get used with more aggressive cams the the captive needle system used by GM can fail also.
    The bushing will take a much greater load, 300X. It will exceed what the rocker will take. With the oil channel we can keep an oil "reserve" on the trunnion at all times. So for a car that sits it will always have lubrication at start up.
    Trunnions are micro polished to an RMA of 2.
    This is not new technology as the OEM have used bushing rockers over the years. Crane used bushings for their shaft rockers.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Tri-Cities, TN
    Both will fail...its just when those pesky little needle bearing fail they like to find themselves in bad places. The bushing will just wear and become noisy.
    Chris Straub
    Straub Technologies
    That's awesome!
    I'd like to know a little more about the "proprietary bushing material". Features and benefits of the material? How does it compare to bronze? Is it a bronze alloy?
    Tri-Cities, TN
    That's awesome!
    I'm curious and would like to know a little more about the "proprietary bushing material". Features and benefits of the material? How does it compare to bronze? Is it a bronze?
    It is a bronze alloy. I've already been told a cam company has bought a kit. I know it is going to be duplicated so at this point I would like them to have to do a little homework before they introduce it at PRI. I hope you understand.
    Chris Straub
    Straub Technologies
    Totally understand. I'm not interested in the proprietary alloy it self, just the features and benefits of the alloy.
    Is it a self lubricating/sintered/oil impregnated bronze bushing? Guess that's the main thing I want to know before I put a set in my "items to buy" list.
    Tri-Cities, TN
    Yes it is self lubricating bronze alloy.
    Chris Straub
    Straub Technologies
    Awesome! Thanks
    ...I've already been told a cam company has bought a kit. I know it is going to be duplicated so at this point I would like them to have to do a little homework before they introduce it at PRI..
    Seems Steve Morris is already there, with what appears to be the same packaging. Different trunions/oiling though.
    Straub Tech
    Steve Morris
    I almost didn't notice the difference in the trunion and was gonna ask if you supplied him with these.
    Straub Tech
    Steve Morris
    I think you have those backwards.
    Quote Originally Posted by scott foxwell View Post
    Totally possible.
    Nope... don't think so.
