Custom Alternator Mount
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default Custom Alternator Mount
    Made a prototype alternator mount today using the only space we had. Mini Denso version. Plan to build a mount for a different engine inline with the crank. Too many belt driven devices on this engine to do that. It will get a little longer belt, powdercoat and stainless bolts. Water is plumbed in the side of the blocks. Can see the water temp sensor in the down view. The water system is reversed and this is the water exit for the engine. It's very sturdy and lines up perfectly. Can be made for most engine alternator combos.
Name:	alternator mount cut.jpg
ID:	875825   Click image for larger version.
Name:	Alternator mount uncut.jpg
ID:	875833   Click image for larger version.
Name:	Alternator mount stands cropped.jpg
ID:	875841   Click image for larger version.
Name:	alternator mounted cropped.jpg
ID:	875849   Click image for larger version.
Name:	alternator mount down view.jpg
    QE 439 Twin Turbo
    That is what they call "thinking outside of the box". Very nice.
    New Port Richey, FL
    Thanks man it turned out pretty good.
Name:	Alternator mount coated.jpg
ID:	876849   Click image for larger version.
Name:	Alternator mount coated2.jpg
    QE 439 Twin Turbo
    Tower Park Resort, Lodi, CA
    Wow! Yeah it did. Really nice
