Header Discoloration
Results 1 to 14 of 16
    Oct 2011
    Sandia,Tx. 78383
    Default Header Discoloration
    What you guys think is going on here ?
    E85 and about 2-4# boost at 30* timing
    Carb builder says not enough timing and excessive fuel burning in collectors , cooking off coating at that point and to bump timing up to 34* to get more burn in cylinders
    any other guesses ? Hate to burn this thing down
    http://oathkeepers.org
    Trust me here. He is correct. The correct cam for a blown gas/ e 85 motor will put more heat in the exhaust than it wants but thats what keeps the cylinders kool.
    V-Drive 4 ever Billdoe's Avatar
    Greenwood , Calif
    2-4 lbs boost? and running E-85? i know i was running 17-18 lbs @34 degrees with Water in headers and it was trying to burn my coating but not bad .. if your not running water in the headers good luck saving the coating
    Oct 2011
    Sandia,Tx. 78383
    I haven't pullied her up yet :+1: gonna go to 6-8# next time out and keep stepping it up till I get about 10-12#. I'm at 9:75/1 on static comp Straub cam builds lots of cyl pressure too
    Just made a couple hits to check fuel system , leaks . Etc etc Fixing to turn up the screw a bit next time And yes these are dry headers
    Senior Member Mr. Denton's Avatar
    Jun 2014
    Mine did that on a naturally aspirated tunnel ram. My wife had accidentally captured a picture of fire in my collectors after I shut down. Added some timing and no more fire. But the headers are definitely scarred.
    Using Tapatalk
    Oct 2011
    Sandia,Tx. 78383
    Not real thrilled about cooking the coatings off a $2k set of headers either
    But if that's the nature of the e85 beast I guess I will live with it
    Peoria, AZ
    Quote Originally Posted by Gopher711 View Post
    It is not that it is E85, it is just that the tune up was not quite happy with what you were looking to get out of it.
    Paul
    Are you using an O2 meter? That will certainly give you an idea where you're at.
    Oct 2011
    Sandia,Tx. 78383
    No but I'm looking into one , Innovate Dual wideband
    you run e85 right ? Where is your tuneup at ?
    I'm running a FAST meter that indicates actual A/F readings, and I think I'm running in the upper 7's. (it's from memory)
    You might find this information on A/F readings interesting from a few years back. http://www.performanceboats.com/gn7-...ml#post1254992
    Oct 2011
    Sandia,Tx. 78383
    How much boost and where is your timing ?
    I'm running 30* locked timing with about 12 pounds boost. (9.4 CR)
    The boost pressure is based on the Blowershop advertised calculations for my engine size and the blower I'm using. (Not actual measured boost on my engine)
    My guess is that i'm closer to 10 pounds boost as most advertised boost is higher than actual boost turns out from what i've heard.
    Jun 2014
    Found the picture of the fire
    Cool picture, not too cool about my headers though.
    Using Tapatalk
    Quote Originally Posted by Mr. Denton View Post
    So, does that mean you have a jet boat of sorts? LOL
