BBC oil pump
Results 1 to 9 of 9
BBC oil pump
    Colfax, Ca
    Default BBC oil pump
    Recommended Melling oil pump for stock BBC. Slight cam, nothing else special.
    Is this real or the "Twilight Zone"?
    Peoria, AZ
    Their standard volume standard pressure stock replacement pump would be fine. Check the clearance between the gears and cover as some are a little big. If you want to go crazy you can get a High Volume pump, but not really needed. If you are not turning a lot of RPM's or crazy stuff you don't need crazy stuff. Depending on the boat a pump support bracket may not be a bad thing.
    Paul
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Melling Select 10770.
    QE 439 Twin Turbo
    Peoria, AZ
    Very nice oil pumps. Every one I have pulled out of the box was right within the tolerances.
    Paul
    Paul
    I have a M-77 melling in my garage new in the box. It's all I run for a below 6k engine. P.M. if you want it. M
    Colfax, Ca
    Thanks for the offer Ol Guy. Summit is delivering one today.
    Apr 2012
    Been running the standard volume/standard pressure pump for 3 seasons now on my 10-1 compression 454 with a mild cam. Oil pressure is always good. Pretty sure the part number is M-7 as well.
    "I'd love to help you out wags, but there is larger issue concerning breast cup sizes on another thread that we have to work thru first. This subject suddenly became a non issue." - GN7
    Paul
    This.
    Salem,Or
    With Spray there is a way!!!
