Bigger blower or Nitrous plate system?
Results 1 to 14 of 16
    Senior Member SLACKER's Avatar
    Glen Allen, VA
    Default Bigger blower or Nitrous plate system?
    I have done some searching on here but havent really found what I'm looking for.
    In a nutshell would it be better to upgrade another size blower(6-71 to a 8-71)or buy a new nitrous plate system and use as an intercooler. Talking about heat buildup...
    I have a 468BBc that is set up for a blower, has edelbrock marine heads,dual 750dp, and a blowershop 6-71. I was thinking of putting the gas on it this summer, to use as an intercooler etc.. But time I buy the kit, fuel lines, fittings, other odds and ends, and not including the refills.I will be almost in the range of stepping up to new 8-71. This isnt a dragboat, its a river layup and its just used for playing around with the occasional race here and there. I think the plate system would be nice to have but where WOULD YOU spend the money. Its gettin late and probably left out some key info but I'm sure you guys will let me know what I forgot.
    Thanks,
    Chris
    MI
    Have you looked into water/meth injection?
    Renegade jet tunneljet's Avatar
    Shorewood Il
    Why not just buy a superchiller?
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    Going from a 6-71 to an 8-71 only gains you 1" of rotor length.
    Have you looked into E-85?
    105 octane, acts like a intercooler and cheap to buy, $2.00 per gal ish.
    Heath Daniel is a member here. Here is his web site. Raceone85.com
    Heath can convert your carb's over and will run them on his car to dial them in for you.
    Plenty of information here e85forum.com
    Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    Quote Originally Posted by Jim W View Post
    Jim
    x2 that's teh cheapest thing to do to get huggggeeee power gain and realllly bring the intake temp wayyyy down if its not available in your area, drop some $$$ into a good intercooler.
    Senior Member HighVoltage329's Avatar
    San Jose, Ca.
    NOS plate system on top of a blower will give you one hell of an increase. I ran that same set up for some time and surprised quite a few. Increasing blower size won't give you the same punch.
    Gone
    Sparks, Nevada
    I'd put 12.5 to 1 trw pistons in the thing, sell the carbs and nitrous, put an injector on it and leave the 6/71 alone. Cam it about 284 @ .050 or so.
    Alcohol would be my intercooler, make more power without the weight.
    4 point of compression makes all the difference.
    Well....you asked what I would do. There ya go.
    Prolly no suprise.
    Glen Allen, VA
    Thanks for the replys guys..
    There are some good ideas, some I'm famaliar (E-85), some I'm not(water/meth). I will do some more homework. I Just got a wild hair and wanted to do some upgrades this year.
    The reason I didnt state the intercooler is some peeps tried TBS intercooler without much of a gain (open transom boats). They said the nitrous worked better than the intercooler. IT's $$$ either way you look at it..
    Fiat,
    No surprise,I would like to eventually go injected down the road...
    Thanks again, I appreciate your time..
    Chris
    Gone
    Sparks, Nevada
    For down the road:
    At 5 lbs of boost...STP
    A 468...blown ...8 to 1 compression....at 100% ve...can do about 572 hp at 6500 rpm
    at 12.5 to one compression....893 hp at 6500 rpm.
    Just to ballpark ya.
    Senior Member littlejockocougar's Avatar
    pleasant hill
    Quote Originally Posted by SLACKER View Post
    Thanks,
    Chris
    I am now on my second water alky injection set up. tradered the old one away. I have an intercooler, and the alky injection. May loose the intercooler. I ran the last water/alky set up w/o intercooler. I have seen pump gas blown motors run 20 lbs. of boost w/34* of timing. The alky system we built is so simple and cheap. I will try to post some pics soon..
    Take a -6 line from manifold ,pressurize a tank , which feeds a spray b ar over the carbs, bingo..... The main thing is to run a check valve so when your not making boost you dont suck the water/alky in on the intake side. plus when your not making boost, you dont need the injection.. No pumps, batteries, switches to fail.. IF YOU HAVE BOOST, YOU HAVE THE INJECTION YOU NEED...Good luck, hope this helps. The mostexpensive part is the one way check valve, ($65-$85), depending on how trick you make your tank.. Steve
    San Jose, Ca.
    Great idea. What size tank are you using?
    pleasant hill
    Quote Originally Posted by HighVoltage329 View Post
    Thanks, I wish it was all my creativity, but I stole the idea from one of my dads buddys old boat. I think my container holds about 2 1/2 quarts. I will get pics soon. Steve
    Silverdale, Washington
    Quote Originally Posted by littlejockocougar View Post
    This deserves it's own thread cuz the approach is so simple. Gotta love that!
    Glad to hear it works for you and would love to see some pics too.
    John
    Fiat,
    Chris
    nitrous doesn't work as well as a intercooler, we went thru that last summer on my uncles blown 540. the nitrous hit hard, but not super impressive and we bent the heaviest duty wrist pins ross made doin it i say intercooler or change the fuel system to e85.
