Ignition box for blown engine
Results 1 to 14 of 21
    Default Ignition box for blown engine
    Which ignition box do you guys recommend for a blown pump gas 548 ci Chevy. I run 11/12 psi of boost. I have been told the blower will blow the spark out if using a MSD 6A/6AL.
    Daytona Sensors.
    My personal thought would be that a 6 MSD would do fine, but I don't know. I run an MSD 7 using about that same boost with no problem for e85 and did the same with AV gas.
    Where can the Daytona box be purchased . Do you agree with what I said about blowing the spark out Scott ? I don't detect a miss with the 6A.
    Senior Member Heatseeker's Avatar
    San Joaquin County, CA
    I've ran a MSD 6AL on a smaller(469 blown jet deal with 10 lbs. for 8 years with no issues.
    Quote Originally Posted by VD Cruiser View Post
    Straub sells the Daytona Sensors but that's not why I recommend them. We sell MSD as well but IMO the DS is a much better ignition. I think the MSD would work, I'm just not a fan. Too many failures.
    Tri-Cities, TN
    Quote Originally Posted by Heatseeker View Post
    That was 2 owners ago. Much has changed. The old stuff is the good stuff.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    waterloo
    I have old MSD 7al boxes... if I did not...
    I would jump on the Daytona sensor piece in a minute. FOR ME.
    I won't tell a guy to buy a new MSD.
    A blown gas piece WON'T blow out the spark. Idiotic internet bullshit.
    BUT...Daytona sensors has tons of advantages... I WILL be buying one for the dyno ignition.
    Wags
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    What about 30 psi with a centrifugal blower? Will the DS support that?
    Oct 2011
    Sandia,Tx. 78383
    Scott , will the Daytona work with the MSD Coil ? I've got a MSD ML3 box I'm thinking of replacing down the road but then I guess I can't use the MSD plug in style modules etc ??
    http://oathkeepers.org
    Quote Originally Posted by ptc View Post
    I know the system will support 1500 hp...maybe more.
    Quote Originally Posted by Gopher711 View Post
    I'm pretty sure the answer to that is no, and no on the modules.
    Re-member
    Feb 2009
    bay area ca.
    I am running a MSD7 with #10 boost on methanol and I have never detected any misfires. And never any failures Im very happy with it.
    ptc
    ptc is offline
    Oct 2010
    Sacramento Area
    Quote Originally Posted by scott foxwell View Post
    Thanks for the reply Scott. The guy that I got this Vortech V4Z system from said he had a problem with ignition when he was running the higher boost. And he was running an MSD ignition system..... (dont know which one) and at 10# boost it was ok, but when he bumped it to the 30# boost pulley it had trouble with ignition.
    So before I go buy MSD stuff and waste time, would I be better off just going with the DS system? Is it just the CD box or do they have a disty, coil and everything? Is it comparable in cost or much more $$$?
