[Question] Timing cover/cam-driven pump question
Results 1 to 5 of 5
    Can't cure stupid 1Homeblown's Avatar
    Sep 2008
    Torrance, Ca.
    Default Timing cover/cam-driven pump question
    I have an old Weiand timing cover and Kuhl water pump. Being naive, I thought they would just mate up in the correct position but I was wrong. The pump centers itself on the cover just fine but the bolt-holes do not line up at all or in any orientation.
    Is it common to have to drill and tap new holes for this to happen? Or would a cam-drive spacer "clock" the pump into the correct orientation? It pains me to have to drill and tap my timing cover.
    Thanks for any info.
    Jun 2010
    I had to drill mine just be careful when you do it
    Peoria, AZ
    Quote Originally Posted by mdsheppie View Post
    Have done it many times, and will do it many more times before I leave this world.
    Paul
    Sep 2008
    Torrance, Ca.
    Thanks for the replies! Its appreciated.
    Jun 2012
    Make sure you check your end play of you cam. I had to spacer mine a few thousandths to get the right tolerance.
