[Question] Camshaft
Results 1 to 6 of 6
Camshaft
    Apr 2011
    Spokane Wa.
    Default Camshaft
    Looking to replace the cam in my motor. It's a 427 bbc 13.1 compression with dart pro 1 310cc heads. I'm running a 850 carb. It's basically a poor man's superstock. Just tryin to get a little more out of it. What are some of the cams they run in superstock. The cam I have now is approx. 654 lift 312 adv. duration 112 lobe center. Any info would be appreciated. Thanks Jeff
    Tri-Cities, TN
    What rpm you want to make peak HP? Have the heads been ported?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Apr 2011
    Spokane Wa.
    Default camshaft
    The heads are stock pro 1. The motor now runs 7200 rpm. I think the cam is too small for these heads. The boat runs about 97mph on gps. Tryin to get up to about 105mph. JeffPS35
    Tri-Cities, TN
    Give an engine a lot of head then you take camshaft away. Depending on the PRO 1 cylinder head size, the cam duration on 430CID should be in the mid 250 range.
    Chris Straub
    Straub Technologies
    Apr 2011
    Spokane Wa.
    Default camshaft
    The heads are 310cc. Would be interested in knowing what cam you would suggest for this application. The springs are set up for a .700 lift cam. Thanks Jeff
    Kent, WA
    Quote Originally Posted by Hondo535 View Post
    Jeff, call Chris direct, he will help you !
