need P/N timing cover gasket for bbc w/.400 raised cam
Results 1 to 2 of 2
    Atlanta TX
    Default need P/N timing cover gasket for bbc w/.400 raised cam
    I found p/n from Flat Out Gaskets #FOG 1249 but it cant ship till after June 6 , are they the only co. that make this gasket ????
    I checked with Alexi at Boostpower. He said they don't use them often since Jesel belt drives have an o-ring, but if need be, he cuts them out of gasket material.
    Another way might be to just use silicone, or if your cam thrust needs .030" gasket, you could cut up a stock one for "shims", and use silicone to fill gaps so the spacing would be correct.
