Crower crank app?
Results 1 to 14 of 39
Crower crank app?
    El Cajon, CA.
    Default Crower crank app?
    A friend of mine has a new billet Crower crankshaft, it's for a BBC, standard sized main journals with hemi sized rod journals (I can't remember the actual numbers right now). Can this crank fit in a Bowtie block with a 10.2 deck height? What can I expect a set of rods to set me back for ($$$$) on a crank like this?
    Gone
    Sparks, Nevada
    Strange. I know lot of guys did hemi cranks with BBC rod journal size (smaller). You need to post that current rod journal size. I am not a Chrysler guy....what I remember is a 426 was like 2.375.
    I'll look some info up.
    Gone
    Sparks, Nevada
    Appears the 392 was 2.375 journal also. I would sure suggest if this is the case to have the crank rod journals turned to 2.200 (BBC). You don't need to be packing all that rod journal in the first place and would simplify everything. Some HP along the way and cheaper bearings.
    For a billet Crower...it's worth it.
    Concord, CA
    Any time you have add ball sizes,or mixed applications, parts become unavailable, at the stock prices.
    On an engine I bought, had Chrysler pin sizes. Broke a rod, Now I must get custom rods, or change the pistons too.
    Jerry
    El Cajon, CA.
    My bone head self forgot to include one of the most important points of my question, it's a 5.1" stroke Crower billet crank, will it fit in a 10.2 Bowtie block?
    I'm going to go out on a limb and say not without a raised cam location. Pan rails may be too narrow as well.
    Quote Originally Posted by billet racing View Post
    Jerry
    Unless they were building a fuel motor, who on earth would decide to use a 1.1 dia wrist pin?
    Brian
    We ran a 4.5" stroke in a Bowtie tall deck and it took a bunch of clearancing. I doubt you'd get a 5.1" to clear. Come to think of it, our Dart block is supposed to be good only to 4.75 and it was easier to clearance than the Bowtie. I'm thinking not enough clearance, Clarance.....
    Was this crank built for a "puller" of some sort ?
    5.1" noway without a raised cam as Steel said, plus David 519 statements.
    S CP
    So is that an opinion or a fact?
    El Cajon, CA.
    It is fact, it will not fit a block with stock camshaft location and the oil pan rails would also be a problem. Thanks for the replies.
    Sleeper I don't know what project the crankshaft was intended for. It was good to see you this weekend.
    I do know that the crank is for sale, PM if interested.
    >> Duh, I'm not a guru, therefore it can ONLY be an opinion
    waterloo
    Please don't take this the wrong way...your friend bought what should have been aborted. If the question is being posed..he bit off more than he can chew.
    Not happening in a bow tie.
    Good, luck.
    Wags
    Good to see you too.
    S CP
