Water presure guage
Results 1 to 7 of 7
Water presure guage
    #41 @ The Islander procraftkev's Avatar
    Corona
    Default Water presure guage
    540 chevy fresh water cooling system were is the best location to plumb the hose to the guage?
    Ladera Ranch
    I've got mine plumbed where the thermostat housing would go. Made a flat cover, drilled & tapped for the 1/8 npt fitting.
    Santa Clarita
    Mine comes off the thermostat housing also.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    i pull mine out the side of the block. Between two freeplugs there's a 3/8" plug (think it's 3/8"), put a fitting there. This is on a mark IV 454 block though, not sure if that exists on a 540.
    Ladera Ranch
    IMO there is too much debris/sand at that point in the block. Thermostat is the highest point and is probably the best spot(IMO). Sure that spot works, just a potential problem area thats all.
    Corona
    Thanks for the help.
    cfm
    cfm is offline
    I see you have an I/O. You can use one of the tapped fittings on your intake manifold in the front crossover passage. I agree, less chance for blockage here.
