Plug recommendation
Results 1 to 14 of 22
Plug recommendation
    Colfax, Ca
    Default Plug recommendation
    468 BBC, 12.9-1 compression, full roller. Pro Comp aluminum heads. Ran Champion 263 with iron heads.
    Is this real or the "Twilight Zone"?
    What type usage? Lake boat, I would probably try an NGK 4091, which is a #7 heat range, non resistor plug, 14mm, .750 reach. Race only perhaps a step colder?
    Colfax, Ca
    Thank you Barry, same plug Scott recommended. Ordered them from Amazon. Nobody local had them
    Senior Member Heatseeker's Avatar
    San Joaquin County, CA
    Be sure to get the ones that screw in fleet. The hammer-in type are tough on them aluminum heads!😂
    Believe it or not, the Pep Boys near me carries them.
    Just Me snoc653's Avatar
    Eastern Iowa
    Just be sure to use anti-sieze on the threads. Hammer out plugs are even harder on heads.
    Not very surprising to me.
    Summit has them also, it's a "racing" plug, keep them on the shelf for engines I build. Blown and turbo engines get 8 or 9 heat range, depending on usage.
    May 2014
    Meadow Vista Ca. Huntington Beach Ca.
    Default Local?
    Riebes has 11 of them on hand. $2.93 each. Is that local enough for you? Probably a better price too.
    Colfax, Ca
    Riebes in Auburn said they didn't have any yesterday
    Would you suggest the same plug for the same engine with 10-1 compression?
    Quote Originally Posted by nos1967 View Post
    Yes,, I use 7's on regular normally aspirated, pump gas engines.
    Apr 2010
    Rocklin, Calif.
    [QUOTE=fleetimus;4176402]Riebes in Auburn said they didn't have any yesterday[/QUOT
    Fleet I get the R5672A-9 at Napa in Loomis or Rocklin...seem to work fine
    Jun 2016
    Cal
    X2 on the 7s
    Colfax, Ca
    Pulled #1 & #2 plugs. Tang is flattened. #7 was not completely flattened. Quit checking them for now. Very frustrated
