Overheated engine
Results 1 to 9 of 9
Overheated engine
    Member garytcosta's Avatar
    Aug 2015
    santa ana, CA
    Default Overheated engine
    Finally got my Rogers on the water this past weekend. Everything was looking good at first, then she started overheating. Ended up pegging the temp gauge. Limped back to the dock & shut down the engine. Everything was hot including the logs & risers, & could hear the water boiling or creating steam in the block & exhaust.
    Even though I have logs & risers, I thought I would be clever & install a pressure relief valve. During the run the valve was leaking & I am pretty sure I had it adjusted to too low of a pressure. After getting it back on the trailer & thinking about it I am pretty sure the pressure relief valve was bleeding off enough pressure that the engine wasn't getting enough water from the pump. Check the dipstick & didn't see any water in the oil.
    The question I have is: Is it possible that I have fried or compromised the engine by running it that hot? Any suggestions on what to do next to determine if I caused any damage?
    454 BBC, mild flat tappet cam, rectangular port heads, compression ratio unknown, probably around 10.5:1
    Thanks in advance for any advice or suggestions.
    Tower Park Resort, Lodi, CA
    If you're not hearing any weird noises, it's probably just fine. Find the cooling issue and run it.
    Aug 2015
    santa ana, CA
    No funny internal engine noises. So it's possible I dodged a bullet?......
    By cutting the flow of cooling water through the engine, you also reduced the amount of water flowing through, and cooling, the exhaust hoses. Failure of those hoses = sunk boat. I would be inclined to give them a very close inspection inside and out. If any doubt, replace them.
    Depending on how hot the motor actually got, you may want to change the oil or at lest check it. Smell it and see how it feels.
    Aug 2015
    santa ana, CA
    Despite the obvious, what features would a compromised exhaust hose have that would be a red flag so to speak??
    G
    Aug 2015
    santa ana, CA
    The oil looks normal on the dipstick, but I have not done a closer inspection yet.
    What am I looking for as far as smell & feel?
    G
    Quote Originally Posted by garytcosta View Post
    G
    Any signs of discoloration or blistering on the outside of the hose. If the outside looks OK, look in through the tips with a flashlight for any signs of blistering there. Personally, I don't think I would be taking any chances and would just replace them.
    Aug 2015
    santa ana, CA
    OS,
    Yeah, they look fine not he outside, have not peeked through the exhaust transom exit yet. Gonna pull both this weekend. probably will just replace as you suggest & maybe keep the old, if still usable, as spares...
