need help on cam
Results 1 to 14 of 26
need help on cam
    Default need help on cam
    i was told this is the place what ihave is a 496 bbc i am building im running aluminum 320 runner rec port heads with 2.225 in 1.8ex valves i also have two 550 carbs from alstate carbs im running on a tunnel ram i have a cam that im thinking about running it is a flat tappet the intake lift is 592 and exhaust is 585 duration @ 50 on int is 245 and ex is 257 is this a good cam for the lower end this is my first jet boat wana make it rite can any one help with this my boat is a 1990 21ft caribbean jet boat with the stock jet my name is joe if any one wants call here is my cell 1 815 651 6219 thanks
    320's are a bit large for a 496 in a big boat like that..guessing a max of about 5400rpm...maybe 5500...It's goign to be a task for an off the shelf cam to make the best of that combination. Wht's the LSA (lobe centers) on your cam? Compression, exhaust, etc. would help.
    ok the lobe seperation is 110 and the comp is 10.1 and i am running basset headers 2inch tubes maybe biger not sure this isnt a off the shelf cam i had it custum ground for a street car i have and never used t went to roller i have the same motor in my street car with the same heads seems to run good just wasnt sure on the boat ok thanks let me nowhat ya think
    hello 496 river i guess first what compression? what exhaust type headers- thru hull ?????? 1/4 mile boat or river blaster
    heads sound decent for a big lift roller combo,
    and the tunnel ram setup is more a mid to upper rpm combo but then the small carbs hurt
    so at this point need alot more info. cant cam a 9.5 comp like a 14.1 motor
    you will find some great info from the guys here.
    if you would put on a set of ported ovals port with large valves and single plane victor jr and a 850 carb
    your going to need all the torque you can get with that 21 foot j
    as for me put a roller in it if you are dollars ahead and you will save $$$$
    yeah i was going to go with oval ports to make a good grunt motor but i pic these up and already had the cam so if i use the cam i have with the specs will it work the 496 should make good power plus tq rite this is just a river hopper from sand bar to sand bar im not racing it but i will have my foot in it alot
    what kind of exhaust?? tube headers or logs or?
    sorry the heads are for 6500 and up and that is hard to patch up with any camshaft design.
    q: is the bottom end built for a small shot of spray. 75-125 hp kit?
    other than that i think your going to hate it.
    yeah there bassets tube headers 2inch out to a four inch and yes i can spray it now why will i need to spray it im so used to street cars if i had this in a car it would run good sorry to seem so dumb but this is my first boat build what do u think this boat would run like a slug with this set up
    i got a set of 049 oval ports i guess i can run they were ported they flow around [email protected] 600
    Quote Originally Posted by 496 river rat View Post
    You'd be way better off with those. You're lookingt at an honest 675-680hp potential (@ 100% ve) with those heads.
    with the 320 heads or the oval ports
    opps i see 049
    Tri-Cities, TN
    What rpm do you want to turn the mill?
    What type of cam is in the engine now? Flat tappet or roller?
    Have you got the flow numbers on either set of heads?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    ok not sure what im wanting to spen this thing i talk to a guy today and he said a jet is like a dyno how ever much power it makes thats what it is going to put to the jet kinda sounds rite he also told me to use isky cam z55 that its a good cam so i think im just gona put it together and spray the shit out of it if i need it like i said its just a river hopper theres just a few guys out here i wana had there ass to ths guy has a 8 fourwinns with the 350 chey mtpi it runs good but gota show him up lol
