Need advice on lash setting
    Anaheim/BHC- the Shack
    Default Need advice on lash setting
    I have a 454 with a solid roller cam of unknown make (engine is assembled and installed), 990 heads, iron block, with 1.7 rockers valve lift at .600". This creates a bit of an issue determining what to set the lash at since I've seen anywhere from .014/.016" for tight lash cams to .028/.030' from Comp Cams. Is there a reasonable "middle of the road" lash setting I can use to fire this? I've heard that .016/.018" is where there will the least chance of having issues.
    Anyone have recommendations on what to look for after firing it to either increase or decrease lash?
    Quote Originally Posted by slowride View Post
    Start at .016/.018 and you'll be fine.
    Op may be slow, but thanks for that info.
    Thanks for the info. First sign of life with what was in the bowls.....
    https://youtu.be/rOyio-g-2dc
