515 ci hyd roller BB Chev, 896 hp
Results 1 to 12 of 12
    Default 515 ci hyd roller BB Chev, 896 hp
    515 ci, 13:1, hyd. roller, 893 hp @ 7100. Heads and intake by Foxwell, cam by Straub, engine built and dyno'd by Mark Jones "Vortecpro".
    Mar 2010
    Clarksville, TN
    Nice work Scott, all these hours you put into these things really pays off
    Tower Park Resort, Lodi, CA
    Is this the short stroke, large bore, tall deck deal you mentioned late last year... that the customer had "huge" heads he insisted on using? If so, you did a great job making them work (well, in any case really)
    You don't happen to have back to back with/without vac pump results, do you?
    Senior Member TexasJet's Avatar
    College Station, Texas
    BEAUTIFUL WORK!!!!!
    No, that was a twin turbo motor that went to the customer to be fit in the car. Hopefully we'll get that back before long to finish up. This is going in a 67 Chevelle. Don't have vac pump details, but I can tell you it's probably 25 to 30 hp.
    Thank you bud.
    BEAUTIFUL WORK!!!!!
    Thanks TJ.
    Nice work.
    What gas did it run ?
    Nice work.
    Thanks Jon. It's a 13:1 motor and ran MS109. Would definitely make more power with something like C16 or Q.
    Peoria, AZ
    Mark seams to be pretty dang good at squeezing potential power out of any combo. Putting your work together makes for a good team. You both do clean and meticulous work. Nice results.
    Paul
    Paul
    Yes he is, very good.
    Thanks Paul.
    Senior Member Futs's Avatar
    Orange CA, Big River
    What size heads Scott?
    AFR 315's with a 2.30 valve and some bowl and short turn work. Ex ports were left stock and chambers were only blended for the big valve.
