Fuel pump problems
Results 1 to 14 of 14
Fuel pump problems
    Default Fuel pump problems
    I have cam driven fuel pump made by chandler-evans ce9141, that carson brummett told me was off of a wwii p51 mustang his guy in van nuys,ca doesn't repair them anymore.the pump works fine it leaks out the driveshaft any information or advice on the repair or were to get parts would be appreciated i know that they were usd on ski race boats
    steve 909-240-2800
    [email protected]
    Quote Originally Posted by 1SNYDER View Post
    steve 909-240-2800
    [email protected]
    Take it apart, can't be that magic inside?
    Or, look for some kind of P51 owners club and ask about getting one repaired?
    My pilot friend is coming up to the river Sunday, I can ask who he knows, and there is another guy up here who was involved with putting the first big blocks in Shelby Cobras, he has a hanger at the airport,, might point you in the right direction, he's a pretty smart old guy.
    Thanks barry,i have emailed aero places,even talked to the company that bought the original manufacturer ,they wouldn't send me a schematic because of legal bs.have partially dissassembled,pretty trick inside full floating ss impellers.just don't want to take completely a part & screw it up hard to find a manual pump & regulator combo.thanks steve
    Just Me snoc653's Avatar
    Eastern Iowa
    I'm sure you've found out that as a still viable aircraft part they will want close to $1000 to rebuild it. Which is why they are tight about releasing information on them. The last thing they want is a home repair to show up and fail on one of they aircraft this pump was originally used on. QAA.com can rebuild it for you. I doubt you can talk them out of the parts or the manual to do it yourself.
    Should look something like this:
    thanks snoc for diagram that will help. I have emailed QAA they want $695 to rebuild it, for that i can buy a Waterman fuel pump I should call them and see it they might sell the part since it isn't on an aircraft
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    That diagram doesn't look like the pump. That pump looks like a typical rotary vane (similar to Holly) pump. The pressure relief returns internally to the inlet. I can rebuild that for you.
    QE 439 Twin Turbo
    Eastern Iowa
    That might not be that exact pump. But, it should be pretty close since its from their pattent. Aircraft parts are just stupid expensive even if it's identical to the same part used in a car.
    New Port Richey, FL
    Yea I thinik I threw away a pump like his not long ago LOL. Pretty sure his is rotary vane. The square on the top is the bypass pressure relief. Been into a ton of them in my A&P days. usually spline drive. Would like to see the drive spud.
    QE 439 Twin Turbo
    Infomanic, what do you mean by A & P days? Yes the spud is splined. Idea of price to rebuild? Thanks Steve
    Eastern Iowa
    I'll help out with part of that for him. A&P = Air Frame and Power Plant = Airplane Mechanic.
    thanks Snoc
    New Port Richey, FL
    It's leaking from the seal? Probably the shaft is worn where the seal rides. Repair that and new seal. $200ish if I have to weld the stainless shaft seal area and machine it back replace the seal. Sometimes a much easier fix. Give me a call or text , i'll be glad to repair it. Do you Facebook?
    https://www.facebook.com/R-D-Special...2719142787280/
    918-269-8084 Ron
    QE 439 Twin Turbo
    New Port Richey, FL
    Pump is ready to come back.
    QE 439 Twin Turbo
