What is it?
Results 1 to 14 of 42
What is it?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default What is it?
    Don't cheat.
    Tri-Cities, TN
    I won't play, I had to get you parts for the thing...
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Senior Member Hydroguy's Avatar
    Ford Nascar?
    Last edited by Infomaniac; 03-25-2009 at 04:08 PM. Reason: Sorry hit edit instead of quote
    New Port Richey, FL
    Quote Originally Posted by Hydroguy View Post
    Ford Nascar?
    Lightning strike from god.
    New Port Richey, FL
    One More Pic.
    Spiral out MikeF's Avatar
    Says 64 409 on the front?!
    Tri-Cities, TN
    Wink
    Ron,
    You got the pistons cocked in the bore. . .they will scuff. . .are you running offset pin bores. . .???
    Chris Straub
    Straub Technologies
    New Port Richey, FL
    Ron,
    Not sure I can get the pistons in yet man. Might be a trick.
    New Port Richey, FL
    Speaking of pistons. What a beast.
    New Port Richey, FL
    I'm running out of playtime. The cylinder heads are a dead giveaway.
    New Port Richey, FL
    A lot of guys might not know what they look like under the cylinder heads. The top of the heads are easily identified. The bottom looks like a diesel engine. No chamber.
    Some guys never learn. bocco's Avatar
    Livermore, CA
    Is that the early 427 that was based on the 409? I think it was called Z-11?
    New Port Richey, FL
    The first pic says what it is on the block. I did'nt get the thinner to it before I took the pic.
    MikeF was observant enough to catch it. That is why I said don't cheat lol
