How Many Tools Does it Take?
Results 1 to 10 of 10
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default How Many Tools Does it Take?
    To machine a connecting rod from a casting?
    New Port Richey, FL
    And no that is not a miniature shop rag.
    Ahhh, for one of those ultra rare taaaaall deck "W" blocks Is there one missing from the pic or is this a 7 cyl? How many of those do you make on a run?
    New Port Richey, FL
    Here is the other one. We cut the small end down. The pin bolts on and is doweled where we rifle drilled the beam.
    We are doing them a short run of 8 at the moment. They need them to finish out the month.
    But we have 50 more castings waiting to run.
    They are 2 cylinder 2 stroke engines.
    Castings or forgings? 'Some big stuff...
    New Port Richey, FL
    Those are castings. We have some similar that are forgings.
    And sometimes I can play with cool stuff.
    For example:
    Overhaul to this mandrel. it is pneumatic and grabs the ID of a 4' or 5' wide coil of steel sheet.
    We have 4 of these cooling tower gearboxes to overhaul.
    These are the cranks to the engine we are doing these rods for. We balanced the cranks.
    And... last but not least. These import bearings. Not enough end play on the cranks during assembly. So we fixtured up and are cutting the thrust surfaces only for them on the CNC mill. About 5,000 of them.
ID:	37068   Click image for larger version.
Name:	gear boxes.JPG
ID:	37069   Click image for larger version.
ID:	37070   Click image for larger version.
    Nechako
    Thumbs up how many tools
    to do the rod from raw cast or just the mod. to the small end ? for just the small end mod. I'm guessing 6 or 7 .....
    New Port Richey, FL
    Casting to nearly finished. 25 tools in this machine. Plus the vertical mill for cutting tangs.
    Nechako
    got ya . wasn't sure if you were doing all the machining . you get quite a variety of work , from 409 's to machining parts for heavy duty as well as job shop repairs
